snielsen
GPIOoutput from Rpi to another Rpi GPIOinput
Fri Jan 19, 2018 3:40 pm
Hello, Im trying to use this script to activate playback on a second Rpi. When button is pressed playback starts on the main Rpi, and the GPIO.output14 goes to a GPIO on the second Rpi. The problem is that the sound on the second Rpi starts without pressing button. I expected the GPIO 14 to be set at 0 untill button is pressed ... I havent included a resistor in the curcuit yet (Iget the in my mailbox soon, that might be the problem?)
I am used to analogue tape recorders and relays, python language is like Chinese to me and Im setting up an solo exhibition with this program in a sound installation soon ... :? :? :?
import RPi.GPIO as GPIO
GPIO.setwarnings(False)
from time import sleep
GPIO.setmode(GPIO.BCM)
GPIO.setup(14, GPIO.OUT)
GPIO.output(14, 0)
import simpleaudio as sa
import time
from gpiozero import Button
button = Button(17)
button.when_pressed = GPIO.output(14, 1)
button.when_released = GPIO.output(14, 0)
while True:
    if button.is_pressed:
        wave_obj = sa.WaveObject.from_wave_file('samples/test3.wav')
        play_obj = wave_obj.play()
        play_obj.wait_done()
    else:
        GPIO.output(14, 0)
        time.sleep (0.1)
pcmanbob
Re: GPIOoutput from Rpi to another Rpi GPIOinput
Fri Jan 19, 2018 4:31 pm
When trying to solve problems like this its good to have a visual indication of what's happening,
so try putting an LED connected in series with a 470 ohm resistor between gpio 14 and ground, then you can see if the output is actually doing what you expect.
and if you are going to use gpio 14 you need to disable the serial interface that normally uses that pin or just use a different gpio.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Burngate
Fri Jan 19, 2018 6:04 pm
... and the GPIO.output14 goes to a GPIO on the second Rpi
Since you're used to analogue tape recorders, you will of course have connected the grounds of the Pis together ...
boyoh
Fri Jan 19, 2018 11:16 pm
Sugest switching the O/P between I/P of the Pi, you use a Opto Isolator
No need to common the grounds, This will give electrical and noise isolation.
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
Paeryn
Fri Jan 19, 2018 11:17 pm
I don't think these two lines do what you think they do. I assume you are expecting pin 14 to go high when the input button is pressed and go low when it is released but that isn't what you have put.
button.when_pressed and button.when_released are supposed to be assigned the function to call in those instances but you have instead assigned them the return value of the GPIO.output() calls at the moment you made the assignments.
GPIO.output() returns None and setting either button.when_pressed or button.when_released to None means don't do anything when that happens. So basically you turned pin 14 high then turned it low when trying to set it up and ended up asking gpiozero to do nothing in response to those events.
snielsen
Sat Jan 20, 2018 8:58 pm
Thanks a lot guys!
by boyoh » Sat Jan 20, 2018 12:16 am
Yes, it sounds resonable to consider this solution if it eliminates noise etc... if I understand it correctly you mean using the same GPIO as in and out on the main Rpi??
Anyhow I found a 340 ohm resistor and tried this code with a led connected to GPIO 2 as output. It seemes to work, and next step is to connect the second Rpi (though I get the correct resistors delivered monday, it might be safer to wait, or is 340 ohm OK?)
GPIO.setup(2, GPIO.OUT)
GPIO.output(2, 0)
import time
button = Button(17)
while True:
        GPIO.output(2, 1)
        time.sleep (0.1)
        GPIO.output(2, 0)
    else:
        time.sleep (0.1)
snielsen
Sat Jan 20, 2018 9:22 pm
The LED gives a short flash(0.1), and yes, it seems to work. But I did not have patience to wait for other resistors, so I connected the second Rpi where the wav file starts playing just by pressing F5 on keyboard, without Buttonpress on main Rpi ... strange to me :|
boyoh
Sun Jan 21, 2018 12:00 pm
Thanks a lot guys!
GPIO.output(2, 0)
import time
button = Button(17)
while True:
        GPIO.output(2, 1)
        time.sleep (0.1)
        GPIO.output(2, 0)
    else:
        time.sleep (0.1)
(-------------------------------------( Pi/1---------------)- (-----(Pi/2)------)(--(Pi/1---)--------------------------(Pi/2)-------------------------------)
GPIO o/p-------( R )----------( a opto k )----0v)- ( 3.3v rail-------( c opto e )----------( 1k )-----------( gpio I/P )--------( 10k )---0v-
Same circuit but in reverse to communicate from Pi 2 to Pi 1
calculate R to give 5ma for op to Transmitter
Circuit shown will give a Active 1 (high ) I/P
Can modifier to give a Active 0 (low ) I/P
davidcoton
Sun Jan 21, 2018 4:53 pm
For single way communication, you can use any GPIO at either end, as long as it isn't doing anything else (and some GPIOs have things assigned by default that you would have to turn off).
I would choose different pins, so that if I ever did need two-way communication, I would have to make fewer code changes (both would transmit on , say, GPIO 2 (pin 3) and both would receive on GPIO 3 (pin 5).
As long as I don't need I2C at the same time.
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
snielsen
Sun Jan 21, 2018 6:40 pm
I still dont understand why the script seems to work well when testing only with LED, and do not work when I connect it to gpio 17 on the second rpi ( playback starts imedeately when jumpers are connected, before pressing input button on main rpi).
pcmanbob
Mon Jan 22, 2018 11:54 am
Then you must have some thing wrong with either your programming or the connection.
with pi's wired like this
the pi with the switch running this code
import time
GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(17, GPIO.OUT)
GPIO.output(17, GPIO.LOW)
while True:
    if GPIO.input(24) == 0:
        print "stop"
    else:
        GPIO.output(17, GPIO.HIGH)
        print "send"
time.sleep (0.5)
and the pi with the LED running this code
import time
GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(18, GPIO.OUT)
GPIO.output(18, GPIO.LOW)
while True:
    while GPIO.input(17) == 0:
        print GPIO.input(17)
        time.sleep(0.1)
    GPIO.output(18, GPIO.HIGH)
    time.sleep(1)
    time.sleep(1)
The LED flashes at one second intervals while ever the button is pressed .
snielsen
Wed Jan 24, 2018 12:15 pm
Thanks a lot, everyone!
My problem is solved. I have inverted the 0 and 1 in GPIO.output(2, x) at line 6, 16 and 18 in the script running on Rpi nr 1.
GPIO.output(2, 1)
import time
button = Button(17)
while True:
        GPIO.output(2, 0)
        time.sleep (0.1)
        GPIO.output(2, 1)
    else:
        time.sleep (0.1)
gpio01 (1).jpg (88.9 KiB) Viewed 429 times
