steve103
How prevent screen going blank with raspian stretch?
Thu Jan 18, 2018 7:10 am
I open a terminal and run a java app from the command line (java -jar...)
After a few minutes the screen goes blank. I assume the pi goes to sleep?
I require that the display stays on the screen (do not require a screensaver also).
I have seen some mails on jessie and wheezy and have not been able to prevent the display
going blank.
have tried (in the command terminal prior to running app), e.g.,
setterm -powerdown 0
sudo xset s off
sudo xset -dpms
sudo xset s noblank
have also tried:
xserver-command=X -s 0 dpms (in /etc/lightdm/lightdm.conf)
Would you know how this can be resolved?
Re: How prevent screen going blank with raspian stretch?
Thu Jan 18, 2018 10:35 am
steve103
Mon Jan 22, 2018 7:47 am
have prevented display going blank after 10 minutes using:
xset s off
xset -dpms
xset s noblank
The display still goes blank after a few hours. Would you have an idea why this might be the case?
n.b. am booting to desktop. - (not console).
thank you
klricks
Mon Jan 22, 2018 1:40 pm
Install xcreensaver then on the main preferences page set MODE: Disable Screen Saver
sudo apt update
sudo apt install xscreensaver
steve103
Mon Jan 29, 2018 7:33 am
I have tried the xscreensaver as in previous note.
However the display goes blank after 3-4 hours.
Would you know what is causing this? how can be fixed?
thank you
bmeissen
Wed Mar 28, 2018 1:14 am
Bumping this up - I've been trying for a few days now to get my model 3B+ to keep the screen on and for the life of me every suggestion does not work.
Paul Hutch
Fri Apr 06, 2018 11:51 pm
This week I got my two 3B's running Stretch with Desktop and my Raspberry Pi Desktop Virtual Machine all keeping the screen on.
  1. Install xscreensaver.
    For the VM I was able to install it from Preferences - > Add/Remove Software
    For the 3B's I had to use klricks command line instructions from above
  2. Reboot so that the xscreensaver service is running
  3. Open the screensaver settings program Preferences - > Screensaver
  4. In the upper left of the Display Modes tab set the Mode: drop down list to Disable Screen Saver
  5. On the Advanced tab uncheck the Power Management Enabled box
tony1812
Sat Apr 07, 2018 12:47 am
I hated the auto blank as well but don't go the xscreensaver route. just another piece of junk to take up space.
Edit this file /home/pi/.config/lxsession/LDXE-pi/autostart, be sure you use this path. There is another autostart file somewhere else, that is the wrong autostart file.
add
@xset s noblank
@xset s off
@xset -dpms
reboot
This works great on my pi3 stretch.
KLL
Sun Apr 08, 2018 3:50 am
do not use this path!
klricks
Sun Apr 08, 2018 4:14 am
Edit this file /home/pi/.config/lxsession/LXDE-pi/autostart, be sure you use this path. There is another autostart file somewhere else, that is the wrong autostart file.
add
@xset s noblank
@xset s off
@xset -dpms
reboot
Please edit your post and correct the path....
alphanumeric
Sun Apr 08, 2018 12:03 pm
xscreensaver will not install for me? Something about not available but referred to by another package?
E: Package 'xscreensaver' has no installation candidate
Latest Stretch release updated and upgraded.
klricks
Sun Apr 08, 2018 12:44 pm
Run sudo apt update and try again.
alphanumeric
Sun Apr 08, 2018 1:07 pm
I did a sudo apt-get update sudo apt get upgrade prior to trying to install xscreensaver. It's doing that on several Pi's that I just did fresh installs on. Will try it again though.
alphanumeric
Sun Apr 08, 2018 1:11 pm
Installing now? I had just done the update upgrade yesterday, is normal to have to do that more than once after a fresh image?
B.Goode
Sun Apr 08, 2018 1:17 pm
It may not be 'normal', but my understanding is that a recent upgrade operation changed the locations of some of the repository sources, so that a further update was needed to activate them for access by your package manager.
alphanumeric
Sun Apr 08, 2018 1:29 pm
Oh well, problem solved anyway. I'm just redoing a couple of other Pi's I did new images on yesterday. It looks like 4 packages are being updated and then the screensaver installs Ok. I would have likely tried it again at some point. The screen constantly blanking while your doing something is a bit annoying.
EinSoldiatGott
Sun Dec 30, 2018 5:19 am
add
@xset s noblank
@xset s off
@xset -dpms
reboot
The path is not valid for raspbian 4.14
pi@RookMotion:~ $ cd  /home/pi/.config/
pi@RookMotion:~/.config $ dir
chromium  lxpanel  lxterminal  user-dirs.dirs  user-dirs.locale
pi@RookMotion:~ $ sudo find / -name "autostart"
find: ‘/proc/706/task/706/net’: Argumento inválido
find: ‘/proc/706/net’: Argumento inválido
find: ‘/run/user/1000/gvfs’: Permiso denegado
/etc/xdg/lxsession/LXDE/autostart
/etc/xdg/lxsession/LXDE-pi/autostart
/etc/xdg/openbox/autostart
/etc/xdg/autostart
/etc/xdg/lxsession/LXDE-pi/autostart worked for me
Best regards
Last edited by EinSoldiatGott on Sun Dec 30, 2018 6:29 am, edited 1 time in total.
klricks
Sun Dec 30, 2018 5:51 am
After the last update the autostart to use now is:
