Trash_Can_Man
Launch another partition OS straight from raspbian desktop
Fri Jan 12, 2018 2:48 am
As the title say, is there any way to reboot straight to another partition with a simple icon on my desktop? my knowledge on linux is limited so maybe im barking at the wrong tree, i actually put my limited google-fu power on action but i ended with 2 possible solution, none of them working/useable:
- https://www.matthuisman.nz/2017/02/kodi ... dd-on.html
This one needs one of the media distros, kodi inside debian do not work (also MAYBE it needs NOOBS, im using PINN, but they are kinda the same iirc)
- http://www.multibootpi.com/
This dude have a pre formed image where you get 4 systems and them all linked with the ability to boot to each other from a simple icon on the "desktop" on each one, but i have 3 problems with this approach 1- the systems are severelly outdated, more than a year off, when you update em the "links" are lost or i have no exact idea of how to re create em 2- i have no idea what that guy have installed on those systems, feels risky 3- about 2 gigs on the SD card are wasted because of how NOOBS handles the 4 images on the SD
As i said im kinda noob and/or missing the elephant in the room sort of speaking, i dont need the solution spoonfed either, with a pointer in the right direction i can keep google-fu-ing on my own.
To be really specific of what i want to do:
pinn (or noobs) with 2 partitions, Raspbian and Retropie, on Raspbian have an icon (direct access, script, watever) calling a reboot directly loading retropie, and on retropie an icon (probably on ports?) to call a reboot direct to Raspbian...
Thanks in advance.
PS: i think i can do something with this:
https://github.com/procount/pinn/blob/m ... -partition
but my scripting skills are super mega basic and its super late over here, thanks for watching and any help is appreciated...
Trash_Can_Man
Re: Launch another partition OS straight from raspbian desktop
Fri Jan 12, 2018 1:38 pm
Another day, fresh ideas, and stronger google-fu-ing, i got this:
viewtopic.php?t=71107#p568213
but apparently its not working, i get a bash error about the file not existing in the folder
PS: that lead me to:
viewtopic.php?t=196094
and from that and using
sudo fdisk -l
and some more google-fu-ing i found that i need to use the small partition on each pair of OSes, basically both pinn and noobs use the 3 first partitons, then in my case i have 2 pairs of 50ish megs partition+main partition, you need to use
sudo reboot 6
where the number is the number of the SMALL partition of each pair, i guess that we run that one because there is loaded the firmware on our rpi3s...
finally i found my own solution after hours of diging, learned a bit more and hopefully helped someone else in the process, sorry for taking forum space with this, thanks and good luck
Return to “Beginners”
