monahanz
Newbie, cannot get a Hellow World to run. please help
Tue Jan 02, 2018 7:24 pm
New here, sorry about this basic question.
I have a Hellow World .c file in a folder /Home/Pi/Public/C_programs called Test1.c
With Geany I can compile fine but it does not seem to make an executable file that runs. In the Geany Set Build Commands I have:-
Compile: gcc -Wall -c "%f" Working Directory: /home/Pi/Public/C_Programs
Build: gcc -Wall -o "%f" Working Directory: /home/Pi/Public/C_Programs
Execute: Working Directory: /home/Pi/Public/C_Programs
Within the sh window I get:- sudo /home/Pi/Public/C_Programs/%e/Test1: Command not found
What is the simple thing I have wrong here?
John
:roll:
scruss
Re: Newbie, cannot get a Hellow World to run. please help
Tue Jan 02, 2018 10:45 pm
Your /Home/Pi should be /home/pi — case matters!
Also, what part is running under sudo? You don't need sudo to build and run commands.
jbudd
Wed Jan 03, 2018 1:44 am
Apart from the upper case issue, do you really have a folder %e ?
scruss
Wed Jan 03, 2018 2:17 am
They're Geany's substitution variables:
geany
Screenshot from 2018-01-02 21-14-24.png (18.77 KiB) Viewed 780 times
If you open a Geany template, it'll set these values correctly for more languages. The ones I showed above were from Geany's ‘main.c’ template.
rhubarbdog
Wed Jan 03, 2018 12:15 pm
Geany is buggy. I have many years experience in computing . When i bought a raspberry pi 3 as a device for my friends child to learn programming. I tried geany and recomended it not be used.
Get any editor with syntax high lighting. Use a terminal to compile and build.
Do your debugging with gdb. Just set your break points and run your program.
rhubarbdog
Wed Jan 03, 2018 12:27 pm
I can't verify this but it appears that %e expands to the file name without .c to run the command in a terminal type
/home/pi/Public/C_Programs/Test1
If geany has an execute button type
/home/pi/Public/C_Programs/%e
Stop typing sudo before your commands. sudo gives you super user authority (root privileges). You're going to break your system if you don't get out of the habbit of typing sudo before each command.
jahboater
Wed Jan 03, 2018 12:45 pm
Try outside of geany for interest:-
cd Public/C_programs
cc Test1.c -o test1
./test1
alternatively just type ...
make Test1
Now you know it really does work, you can focus on building it in the IDE.
jbudd
Wed Jan 03, 2018 12:56 pm
It's certainly true that I know nothing of Geany or it's substitution variables. However that command line looks like sudo is attempting to find /home/Pi/Public/C_Programs/%e/Test1. If this is running within Geany and %e evaluates to Test1 then sudo is looking for /home/Pi/Public/C_Programs/Test1/Test1
So is /home/pi/Public/C_Programs/Test1 an executable file or a directory? What does the command "file ~/Public/C_Programs/Test1" show you?
scruss
Thu Jan 04, 2018 3:08 am
Geany is buggy.
‘citation needed’, as the kids today might say. While I don't like it as an IDE, it works for the small projects I throw at it.
monahanz
Fri Jan 05, 2018 6:05 am
Thanks for the fast reply everybody. This group is great. I come from the Intel/Edison group that takes days for a response!
First I actually had “/Home” as /home – I just typed it wrong in the forum message.
:oops:
I now notice that I cannot get make working . Below is my configuration file. What needs to be corrected to have an executable in /home/pi/Public/C_Programs
John
rhubarbdog
Fri Jan 05, 2018 9:11 am
Remove that sudo from your execute command if if needs any thing other than ./%e or /home/pi/Public/C_Programs/%e then its bash
rhubarbdog
Fri Jan 05, 2018 9:13 am
If you really need to use sudo from geany then it should be gksudo
scruss
Fri Jan 05, 2018 3:50 pm
Please give us the results of this command:
ls -l /home/pi/Public/C_Programs
Geany's warning about Invalid Working Directory “/home/pi/Public/C_Programs” makes me think that folder doesn't exist. You can fix that with:
mkdir -p /home/pi/Public/C_Programs
Have you tried Geany's File → New from template → main.c option? It sets all the build and run options, so you can save your C where you want and it handles all the folders and compilation variables.
monahanz
Fri Jan 05, 2018 7:06 pm
Thanks rhubarbdog , removing the sudo did the trick!
Who is online
Users browsing this forum: No registered users and 17 guests
