I eat Pi
Rasberry pi 3 login
Tue Jan 02, 2018 10:31 am
I have set up my rpi 3 and installed raspberian
I load it up and the scrolling text appears and goes on for a few secs and then stops at account login still on the text
what do i enter there
k-pi
Re: Rasberry pi 3 login
Tue Jan 02, 2018 2:50 pm
Try pi then raspberry. ;)
Tue Jan 02, 2018 3:01 pm
Did you install ?
Raspbian Stretch Lite
or
Raspbian Stretch with Desktop
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
I eat Pi
Tue Jan 02, 2018 3:53 pm
Lite
piglet
Tue Jan 02, 2018 4:12 pm
Ahh - OK. You having two threads doesn't help.
Raspbian lite is fine where you're comfortable with a command line interface and don't need a desktop GUI interface.
It sounds like you need to download and install "Raspbian Stretch with desktop" from https://www.raspberrypi.org/downloads/raspbian/
I eat Pi
Tue Jan 02, 2018 4:41 pm
Im new so ill try to install it
I eat Pi
Tue Jan 02, 2018 4:45 pm
Can i wipe the sd card
And start again
piglet
Tue Jan 02, 2018 4:52 pm
Yes, no problem.
Use the same process to write to the card as you did the first time. You don't need to wipe the card first.
Tue Jan 02, 2018 4:55 pm
And start again
On your PC download Radpbian stretch with Desktop .zip
On your PC download Etcher
https://etcher.io/
Etcher will both unzip and create a bootable SD Card, no requirement for formatting, Etcher will undertake this as well. A very good all in one software.
adieu
I eat Pi
Tue Jan 02, 2018 6:13 pm
Yes, no problem.
How do i do it with out wiping it?
I eat Pi
Tue Jan 02, 2018 6:15 pm
I have the pre formatted sd
