~ $ sudo apt-get remove signal-desktop
Reading package lists... Done
Building dependency tree
E: Unable to locate package signal-desktop
The OP clearly didn't manage to install it because of the architecture mismatch. That's why it failed to un-install.
DougieLawson wrote: ↑Fri Dec 29, 2017 9:35 amThe OP clearly didn't manage to install it because of the architecture mismatch. That's why it failed to un-install.
$ curl -s https://updates.signal.org/desktop/apt/keys.asc | sudo apt-key add -
$ echo "deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main" | sudo tee -a /etc/apt/sources.list.d/signal-xenial.list
$ sudo apt update && sudo apt install signal-desktop
~ $ sudo apt-get update
Get:1 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
Hit https://updates.signal.org xenial InRelease
Hit https://updates.signal.org xenial/main amd64 Packages
Get:2 http://mirrordirector.raspbian.org jessie/main armhf Packages [9,536 kB]
Hit http://archive.raspberrypi.org jessie InRelease
Get:3 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Get:4 https://updates.signal.org xenial/main Translation-en [388 B]
Get:5 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Get:6 https://updates.signal.org xenial/main Translation-en [388 B]
Get:7 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Get:8 https://updates.signal.org xenial/main Translation-en [388 B]
Get:9 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Get:10 https://updates.signal.org xenial/main Translation-en [388 B]
Get:11 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Ign https://updates.signal.org xenial/main Translation-en_GB
Get:12 https://updates.signal.org xenial/main Translation-en [388 B]
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:13 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [43.3 kB]
Get:14 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [84.2 kB]
Get:15 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,680 kB in 2min 0s (80.3 kB/s)
noobtron wrote: ↑Wed Jan 03, 2018 6:47 pmOn the Signal website, it gives the following commands to install Signal on Debian based distros:
https://signal.org/download/#linuxModal
$ curl -s https://updates.signal.org/desktop/apt/keys.asc | sudo apt-key add - $ echo "deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main" | sudo tee -a /etc/apt/sources.list.d/signal-xenial.list $ sudo apt update && sudo apt install signal-desktop
Yea, I understand that it's for the wrong version of Linux now. I will be more vigilant in checking the version next time I go to install anything.fruitoftheloom wrote: ↑Wed Jan 03, 2018 6:54 pmnoobtron wrote: ↑Wed Jan 03, 2018 6:47 pmOn the Signal website, it gives the following commands to install Signal on Debian based distros:
https://support.signal.org/hc/en-us/art ... l-Desktop-
Future reference the clue it is wrong is in AMD64 in the download link, Raspbian is ARMHF !!!!
~/.config/Signal
bash: /home/pi/.config/Signal: No such file or directory
ashes walls wrote: ↑Tue Mar 13, 2018 1:08 pmthere is some problem with it. how to solve it?
Unable to use properly![]()
I am very upset after using this.
Users browsing this forum: fred44nl, mnavon, pcmanbob, shreyasaha25 and 30 guests
