noobtron
Signal Desktop Removal
Thu Dec 28, 2017 8:00 pm
I tried to download Signal Desktop for my Raspberry Pi and was unable to locate it. I figure that there is something incompatible with Raspbian. I tried to uninstall it, but it says that it can't be located. I know it's there because every time that I do an update, it says that it's updating Signal. Any ideas on uninstalling this?
~ $ sudo apt-get remove signal-desktop
Reading package lists... Done
Building dependency tree
E: Unable to locate package signal-desktop
mahjongg
Re: Signal Desktop Removal
Thu Dec 28, 2017 9:35 pm
I don't think signal-desktop exists for the PI, just that there exists an (x86) Linux version doesn´t mean it was ported to ARM Linux for the PI.
noobtron
Fri Dec 29, 2017 2:07 am
Thank you for the response! I still have a lot to learn. Any idea how I would uninstall it? After all, the Pi is "updating" it every time I do an update.
Fri Dec 29, 2017 9:15 am
How did you install the software originally ??
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
Fri Dec 29, 2017 9:35 am
The OP clearly didn't manage to install it because of the architecture mismatch. That's why it failed to un-install.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
Fri Dec 29, 2017 9:47 am
......does not appear to be an install from Debian Repos:
https://support.signal.org/hc/en-us/art ... l-Desktop-
noobtron
Wed Jan 03, 2018 6:47 pm
On the Signal website, it gives the following commands to install Signal on Debian based distros:
https://signal.org/download/#linuxModal
$ curl -s https://updates.signal.org/desktop/apt/keys.asc | sudo apt-key add -
$ echo "deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main" | sudo tee -a /etc/apt/sources.list.d/signal-xenial.list
$ sudo apt update && sudo apt install signal-desktop
It's clear that Signal did not "install". However when I update, it makes it clear that my Pi is still connected to the Signal repo in some form or another because it's listed in my updates.
~ $ sudo apt-get update
Get:1 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
Hit https://updates.signal.org xenial InRelease
Hit https://updates.signal.org xenial/main amd64 Packages
Get:2 http://mirrordirector.raspbian.org jessie/main armhf Packages [9,536 kB]
Hit http://archive.raspberrypi.org jessie InRelease
Get:3 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Get:4 https://updates.signal.org xenial/main Translation-en [388 B]
Get:5 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Get:6 https://updates.signal.org xenial/main Translation-en [388 B]
Get:7 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Get:8 https://updates.signal.org xenial/main Translation-en [388 B]
Get:9 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Get:10 https://updates.signal.org xenial/main Translation-en [388 B]
Get:11 https://updates.signal.org xenial/main Translation-en_GB [391 B]
Ign https://updates.signal.org xenial/main Translation-en_GB
Get:12 https://updates.signal.org xenial/main Translation-en [388 B]
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:13 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [43.3 kB]
Get:14 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [84.2 kB]
Get:15 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,680 kB in 2min 0s (80.3 kB/s)
Wed Jan 03, 2018 6:54 pm
Future reference the clue it is wrong is in AMD64 in the download link, Raspbian is ARMHF !!!!
noobtron
Wed Jan 03, 2018 7:06 pm
Yea, I understand that it's for the wrong version of Linux now. I will be more vigilant in checking the version next time I go to install anything.
I did try both of the methods that you mentioned on the link that you supplied. I had actually tried them already when I first started this thread. This is what I get when I try to execute those commands:
~/.config/Signal
bash: /home/pi/.config/Signal: No such file or directory
noobtron
Thu Jan 04, 2018 3:53 am
I went ahead and just reinstalled Raspbian. It seemed like it was probably to complicated of a fix and I didn't really have any important info anyway. Thanks anyway guys! I really appreciate that you all had such a willingness to help.
Who is online
Users browsing this forum: scotty101 and 33 guests
