How install OpenJDK using tar.gz file - without internet access?
Posted: Tue Dec 19, 2017 1:37 am
by steve103
I have (currently) installed noobs/raspbian (from https://www.raspberrypi.org/...) on to the SD card for use with a raspberry pi 1.
I require to install OpenJDK (at least/probably v8) - however I do not have internet/ethernet access.
Therefore I would like to copy tar.gz file on to SD card (by mounting SD card on to laptop).
I am not sure which tar.gz file to use?
From the jdk.java.net web site, there is:
jdk-8u162-ea-bin-b03-linux-arm32-vfp-hflt-24_oct_2017.tar.gz
Would this be compatible/ok to install?
where would I download tar.gz files from?
thank you
Re: How install OpenJDK using tar.gz file - without internet access?
Posted: Tue Dec 19, 2017 4:05 pm
by knute
That file looks fine to me but you can also go to: http://www.oracle.com/technetwork/java/ ... 33151.html to get the latest released version.
Are you running NOOBSLITE? Because the Java8 JDK is already installed in the full version and you don't need to install anything.
Posted: Wed Dec 20, 2017 2:06 am
by KLL
you mean "RASPBIAN lite"?
Posted: Wed Dec 20, 2017 4:13 pm
by knute
So I knew if I said Raspbian lite somebody would say no NOOBS Lite.
