makem
Is it possible to VNC securely from a mobile phone?
Mon Dec 18, 2017 1:05 am
From a Linux pc I can issue the following commands to tunnel a VNC connection to the VNC server on my pi from the WAN:
ssh -L5901:localhost:5901 [email protected] -p443
While that is running:
vncviewer localhost:1
I am wondering if I could do the same from a mobile phone in some way, ie. duplicate the Linux Terminal to make those commands?
I have tried a number of ssh apps but none accept commands in that form.
mattmiller
Re: Is it possible to VNC securely from a mobile phone?
Mon Dec 18, 2017 8:22 am
Might be worth trying an android VNC app that uses ssh directly - bVNC seems to be one
makem
Mon Dec 18, 2017 7:30 pm
Thank you, that looks promising. I have the pro version now.
However I am getting an error:
"Failed to authenticate to SSH server with key-pair please check your SSH username and ensure your public key is in the authorized_keys file on the remote side."
The key generated by bVNC is in the /.ssh/authorized_keys file of the pi, I am using the same username used to successfully to ssh into the pi.
So, unless the authorized_keys file needs to be somewhere else I fail to see why I am getting the error. Unless, bVCN is not compatible with the VNC server supplied in Raspbian.
mattmiller
Mon Dec 18, 2017 9:11 pm
I think your right - I couldn't get bVNC to connect even without using SSH
I've go an alternative working but not using key files as I've never used them
I installed ConnectBot and managed to use the standard realVNC droid app to ssh tunnel to my Pi
https://shantanugoel.com/2010/08/02/ssh ... g-android/
So I don't know if it will work using key files but maybe worth a go
makem
Mon Dec 18, 2017 9:26 pm
I think I will stick with bVNC having paid for it! Need to find a manual or guidance though.
Apparently x11vnc is the way to go. I've used that in the past.
knute
Tue Dec 19, 2017 4:24 pm
Raspbian comes with a RealVNC server installed. There is an Android VNC client app and probably one for the other OS' too. I think the encryption in RealVNC is more than adequate for your phone.
makem
Tue Dec 19, 2017 4:57 pm
Hi, thanks for taking the time to make the comment.
I stay in a private house with family in China. They tell me that when a foreigner visits, the local boy hackers 'try it on'. I've paid for bVNC and I've installed x11VNC so I intend to make those work. But it is going to be a steep learning curve when I don't yet understand the basics of tunnelling, ssh and keys use. I think a library visit is called for to get a basic grasp of the concept. A lot of what I read on the web is confusing and contradictory.
makem
Tue Dec 19, 2017 8:14 pm
I have bVNC working now using keys with x11VNC. It is on external port 443 and forwarded to the pi 22. I am using a passphrase but maybe that is OTT and a pain to keep having to type in.
I have an s8 phone and the viewer is offset to the right in landscape view but is moveable and zoomable.
Now I need to learn the screen finger moves which I've seen listed somewhere
