IvanRRR
Create new partition in a 64Gb SD?
Sun Dec 10, 2017 10:59 pm
Hi there,
I'm trying to install everything in a RPI3 and I have a 64Gb Samsung SD (Evo XC). The computer I use is a Mac.
I formatted the card with SD Card Formatter 5.0.0 and in principle it uses ExtFAT so that you can use the 64Gb.
Then I installed raspbian, and it works, but I only see a FAT32 partition which is completely used and I can't do anything else and I don't know if I can create another partition either.
Can I install raspbian in a way that it doesn't reformat the SD? Actually what I want to install mainly is LibreELEC. Any recommendation?
Many thanks!!!
KLL
Re: Create new partition in a 64Gb SD?
Mon Dec 11, 2017 1:19 am
-a- 64GB card formated exFAT is useless ( for NOOBS ) https://www.raspberrypi.org/documentati ... matting.md
-b- installed RASPBIAN anyhow would mean you burned a RASPBIAN image ( ? by etcher? win32diskimager?)
so step -a- formatting not needed.
missing info what file (full name) you downloaded and installed how?
-c- in case that burning RASPBIAN gave you a running system
you should check from there the actual partition layout
( and not from a windows PC where you only see one ( the first 68MB partition )
use the terminal commands
df -Th
and
lsblk
and show the results here.
-d- for working ( and learning linux... ) you should use RASPBIAN ( better burned to a other 8GB SD card )
for download burn LibreELEC https://www.raspberrypi.org/downloads/
-e- if you want both as a multiboot SD card go back to the formatting point,
do it correctly for 64GB cards ( not exFAT )
and download / unzip/ copy the files from
NOOBS full
NOOBS lite
PINN lite
and ( with internet connection ) download install both OS via NOOBS menu.
-f- to the question:
you could do by using RASPBIAN...
install "gparted"
and resize / create ... partitions,
but if you asked this regarding to install openELEC additionally to the already installed RASPBIAN
on that card, sorry, not work that way. ( see -e- for multiboot )
IvanRRR
Mon Jan 01, 2018 12:20 pm
Hi KLL,
Thank you so much for your complete answer. Actually I didn't want to install any specific OS or SW. I just want to be able to watch movies and I'm open to any suggestion. I tried to give as much information as possible, but maybe it was more confusing.
So, knowing that I have a 64Gb and I would like to use it with my RPI3 as media center (kodi and so on), what do you suggest that I do, starting from scratch? Install NOOBS you said, right? What else? Thanks again!!!
Ivan
Mon Jan 01, 2018 12:30 pm
Hi KLL,
Ivan
If you just want KODI Multimedia Centre Software then install LibreElec, they offer specific downloads for the various Raspberry Pi Boards:
https://libreelec.tv/
Etcher can both unzip and create a bootable SD Card (no formatting required):
https://etcher.io/
The Raspberry Pi OSes can understand FAT 12/16/32 & EXT file systems, for OSX/MacOS and EXT see:
http://osxdaily.com/2014/03/20/mount-ex ... ystem-mac/
