sinonimos wrote: ↑Fri Dec 08, 2017 10:49 pmAfter a few years I have decided to pick up with my raspberry pi again, starting from the ground up. I already had an old noobs version on an SD card and was working with that when I thought I would download noobs onto another SD card using the latest Noobs version v2_4_5. It took ages and was much bigger than the previous version I had been using. Once downloaded it was effectively too slow to use. My question is what is the command line to give me full information about the Noobs I have on my original SD card and can it give me more detail about the model of my raspberry pi? I think it is a B model. If so can I still access the earlier Noobs versions? The raspberry pi website only seems to offer the noobs_v2_4_5 version that looks like a regular windows computer rather than the cut down style with the big raspberry logo in the centre of the screen.
sinonimos wrote: ↑Sun Dec 10, 2017 8:07 pmThanks for your help Scruss Using theuname -aand the free -hcommands helped me to establish that I probably do have a model B raspberry pi, with 512MB. no luck with the cat/proc/cpuinfo but got a lot of results from less/proc/cpuinfo. So I guess your suggestion put me on the right track.
Thanks to KLLtoo. I tried the NOOBS (lite) you mentioned but I would prefer some kind of Graphic Interface, like the big raspberry and a few shortcuts/drop down menus to click on the screen. I did try to unzip the downloaded Raspbian Strech (full) but it kept throwing a message back at me saying that I didn't have enough space on the hard disk, when I clearly did. I noticed it was zipped in an Image folder and the the Rasberry webpage downloading instructions said I had to use a program called Etcher. It gave me a few choices for Windows, such as a x64, 64 bit, portablea x86, 32 bit, installer and a x86, 32 bit, portable. I am using a fairly old Windows 7 Operating System with a 1000GB internal hard drive and a 500GB external back up hard drive. Which one would you suggest I choose? As for the PINN! I checked out something about it on Youtube and for a beginner like me it looked out of my league. To answer your questions "Why I stopped using my PI?" and "What I wanted to use it for in the first place?" well I guess I just got sick of hitting brick walls trying to figure things out on my own with books and computer links. Maybe a forum approach will help me more to unlock some computing secrets. Regarding the second question, I just wanted to expand my computing curiosity and see what applications I could adapt it to.
And finally, many thanks to Fruitoftheloom. I checked out the Tiney Core Linuxand at this stage of my relearning curve it looked too spooky , just like the PINN.
-A- -C-sinonimos wrote: ↑Sun Dec 10, 2017 8:07 pm-A-
-B-
-C-
-D-
