Welcombe2000
Raspberry Pi 3 connection to a breadboard
Thu Dec 07, 2017 10:29 am
I'm a complete beginner! What do I need to connect a Pi 3 to a breadboard. I don't have a breadboard so I would be happy to buy a kit.
jbudd
Re: Raspberry Pi 3 connection to a breadboard
Thu Dec 07, 2017 12:14 pm
A starter kit like this https://www.amazon.co.uk/Smraza-Breadbo ... B01I0ZEK48 would give you plenty of scope for experiments.
You might also consider adding a little board like http://rasp.io/portsplus/ to help avoid misconnections on the Pi
piglet
Thu Dec 07, 2017 12:29 pm
Or do a search for "Raspberry pi Cobbler" - that will bring up a whole range of connectors from Pi to breadboard which combine the benefits of the previous post with actually getting the connections on your breadboard.
(I just use jumper wires myself - but the cobbler boards probably make it safer!)
Welcombe2000
Thu Dec 07, 2017 12:44 pm
Thanks, I'll check each out and get shopping! :D
pcmanbob
Thu Dec 07, 2017 3:12 pm
Instead of buying on of those you can print your own and just punch out the holes using a sewing needle and slip it right over the gpio pins just the same, easy to replace once it gets a bit warn being paper you can also make notes on it.
Here's my version if you want to try it, down load from google drive link
https://drive.google.com/file/d/1lhtX6N ... sp=sharing
