barrettj103
Continuous rotation servo control.
Wed Dec 06, 2017 10:11 am
I have looked at several posts on this issue and have not really found an answer. My first question is how the 1000, 1500, and 2000 micro second bursts translate to the ChangeDutyCycle variables? I have tried many different numbers but can't really figure out what the pi is doing. I am using what seems like the standard code for learning servo behavior.
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(12, GPIO.OUT)
p = GPIO.PWM(12, 100)
p.start(5)
time.sleep(5)
p.stop()
GPIO.cleanup()
This code runs it clockwise at a good speed, but it never stops. I am running this over ssh, but I don't see why that would make it not stop
All I need it to do is run clockwise for a set (Short) period of time and then stop until the method is called again. Any help will be appreciated.
I'm also looking to learn this for any future projects I might do so the more info the better.
joan
Re: Continuous rotation servo control.
Wed Dec 06, 2017 11:19 am
I suggest you use (my) pigpio or servoblaster or RPIO.GPIO for servo pulses. They each use hardware timed pulses. Software timed pulses will be much more subject to jitter (which will shorten the servo's life).
E.g. http://abyz.me.uk/rpi/pigpio/pigs.html#S/SERVO
SurferTim
Wed Dec 06, 2017 12:52 pm
This method requires hardware, but it takes the processing load off the RPi. I use this, and I'm very pleased with the performance.
https://www.adafruit.com/product/815
pcmanbob
So the reason your servo does not stop is because you have not told it to, most servos will hold the last position you set them to but as yours is a Continuous rotation servo it will just keep spinning.
To make your servo stop you need to set the duty cycle to the mid position, try this you may need to adjust the middle value to find the exact value to make your servo stop
import time
p.start(5)
p.ChangeDutyCycle(2.5)
time.sleep(5)
p.ChangeDutyCycle(11.5) # may need to be adjusted
time.sleep(5)
p.ChangeDutyCycle(20.5)
time.sleep(5)
GPIO.cleanup()
[code]
you servo should turn in one direction then stop then turn in the other direction then stop.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
PiGraham
Wed Dec 06, 2017 1:35 pm
So the reason your servo does not stop is because you have not told it to.
Agreed.
It may be the case that no PWM signal will stop the servo.
If not it may be necessary to maintain the mid-position signal and not quit with GPIO.Cleanup().
scruss
Wed Dec 06, 2017 4:01 pm
For much higher level control, there's also gpiozero.Servo. Punch in the particular servo's timing parameters from the data sheet (or failing that, ServoDatabase.com) and then just feed it values from -1 .. +1, with 0 for stopped.
mikerr
Wed Dec 06, 2017 6:53 pm
A normal servo goes to a selected position, then stops.
A continuous rotation servo is controlled in a similar way, but :
- sent a position of "centre" it will stop (at e.g. 90)
- sent a position away from center (e.g. 75 or 150) it will rotate continuously,
- rotate direction will depend on which side of the "centre" the position pulse was.
- on some serves rotate speed also depends on how far from centre the pulse is.
Note the "centre", or no-movement position can vary between individual servos
I have identical ones here where centre is 90 on one, 93 on the other !
Also very new is the parallax 360 feedback servo:
https://www.parallax.com/product/900-00360
which has an extra wire to provide exact positional angle feedback.
evaoxo
Wed Oct 03, 2018 12:08 am
Hi, do you have a simple example python code for the motor you suggested?
I’m currently using this motor, but I don’t know how to control it with different speed and how to do with the feedback since there is no 360 servo library in python.
danjperron
Wed Oct 03, 2018 1:32 am
The PWM for Rpi.GPIO works in percent.
Normal servo use a cycle of 20ms (50Hz)
Then
1000 us = 1000us / 20000us * 1000 = 5
1500 us = 7.5
2000 us = 10
import time
p = GPIO.PWM(12, 50)
print("center")
p.start(7.5)
time.sleep(2)
print("45 degree")
p.ChangeDutyCycle(5)
time.sleep(2)
print("The other 45 degree")
p.ChangeDutyCycle(10)
time.sleep(2)
print("Center again")
p.ChangeDutyCycle(7.5)
time.sleep(2)
print("stop")
p.stop()
GPIO.cleanup()
[code]
RPi.GPIO use software PWM. it is not steady!
