kaksi
Writing files with owner=pi instead of owner=root
Tue Nov 28, 2017 12:38 pm
I have a Python program with the instruction:
camera.capture(jpg_name)
I call Python from /etc/profile:
sudo python /home/pi/cam/PI_CAM.PY
I guess the owner is root because I call the script with sudo. The obvious solution does not work: if I call the script w/o sudo, the script does not run.
One way is chown after each snap. Not very elegant.
BTW, this script is re-executed when I connect with ssh or putty - not my top list problem now, but it would be nice to solve it too.
Any idea?
RaTTuS
Re: Writing files with owner=pi instead of owner=root
Tue Nov 28, 2017 12:43 pm
change it so it does not run as root
change whatever you need that needs it to be root so it is not
dont stuff it in /etc/profile
I assume you want it to auto run
then put something like
if [ $(tty) == /dev/tty1 ]; then
   ./script
fi
.bashrc in user pi home directory
post your script here so we can dissemble it to make it so it does not need root.
Covfefe
topguy
Tue Nov 28, 2017 4:12 pm
Also check the owner of "cam" directory, the script itself and the directory where he pictures are saved.
Tue Nov 28, 2017 5:44 pm
Stop running everything as sudo. 99.99999% of programs DO NOT need to run as root.
This is a doctor free zone.
kaksi
Tue Nov 28, 2017 7:41 pm
put something like
   ./script
fi
Works perfectly. Thank you very much.
If it comes handy to others, what to avoid:
- do not save these lines with notepad and include the file with nano; .bashrc will be saved in DOS format (some scripts do not mind, this does)
- when typing the code, spaces matter a lot
W. H. Heydt
Tue Nov 28, 2017 8:29 pm
That sort of problem is easily fixed...at least in vi. If you have to strip off the extraneous ctl-M, then use :g/^v^m/s/// where ^v is ctl-V and *m is ctl-M. To get rid of blank lines you can use :g/^$/d where * is really a caret and $ is really a dollar sign.
Ctl-V acts as an escape character in vi and prevents the ctl-M from being an actual carriage return. ^ is the begging of the line and $ is the end of the line, so ^$ is a line with nothing on it.
DirkS
Tue Nov 28, 2017 8:54 pm
And for simple people like me: use dos2unix
asandford
Wed Nov 29, 2017 2:22 am
If you have to edit on Windows (don't know why, vi's fine), use notepad++
