lerner
WMCTRL command help please.
Sun Nov 26, 2017 9:34 pm
Folks,
I am trying to get my head around using this command: wmctrl.
What I am wanting to do is have a command to force the terminal window to the front.
From what I see that is "easy" in you do the command:
wmctrl -r <window name> -b add,above
Ok, got it. But if I want THIS WINDOW as the window name, how do I do that?
I can't quite work out the quirkyness of linux yet to understand that part.
Is it possible?
Thanks in advance.
P.S.
I also understand that I will probably have to then toggle/remove the "above" so the window isn't stuck above all others.
topguy
Re: WMCTRL command help please.
Mon Nov 27, 2017 11:59 am
I'm not sure what you are asking, are you asking how to set the window name when you open a terminal window ? Or how to replace "window name" in the wmctrl command. ( TIP: your not supposed to include < > )
Personally I prefer the xdotool. http://www.semicomplete.com/projects/xdotool/
lerner
Mon Nov 27, 2017 8:29 pm
Hi.
The "idea" is that have an open (RANDOM) terminal/CLI. By that I mean one I don't want to have to name. The path is also not to be anything specific. It could be Anywhere.
I start some task and it is going to take some time. Say: sudo apt update
I don't want to have it at the top all that time.
So I get on with other things.
So.... After the command I && a new command so when it is done, it brings that window to the front.
WMCTRL can do that to a "named" window - which can be the one in which it is launched. But on the proviso that THAT window's name is known.
So I am asking is it possible to use WMCTRL to bring the window in which it is run to the front?
From what I have read xdotool has the same limitation: In that it can't execute commands on it own window unless it knows the name.
I'll have a look at the link anyway, but as I said: From what I read that needs the window name too.
