Wifi query
Posted: Fri Nov 24, 2017 9:06 pm
I have a problem with my WIFI going to sleep, I have googled it endlessly but what every I try, fails. I did have it working up till a week ago when I got a new router, I (for some reason) wiped the interfaces file and started a fresh, since then the problem is simple the WIFI goes to sleep
I have also tried to have a static IP but thats not working either.
My raspberry is running Wheezy, Headless.
My interfaces file
My wpa_supplicant.conf
I have tried this
/etc/modprobe.d/8192cu.conf
After I restart the raspberry the router see it and it gets two IP's the 227 is the one I use to SSH, the 6 is the one I tried to fix it too.
Can anyone help, or at least point me in the right direction!
Regards
James
My interfaces file
auto lo
iface lo inet loopback
iface eth0 inet dhcp
wireless-power off
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.1.6
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.1
#allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
update_config=1
network={
ssid="SomeID"
psk="Somepassword"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0 rtw_ips_mode=1
raspberrypi 192.168.1.227 192.168.1.6
Regards
James
