seprim
Use a RPi3 with 5.5V
Fri Nov 24, 2017 9:39 am
Hello
Is it possible to supply an RPi3 with an 5.5V voltage regulator?
You can never solve problems with same reasoning, by which they were created. (Albert Einstein)
I do not agree with the mathematics. I mean, that the sum of zeroes is a dangerous number. (Stanislaw Jerzy Lec)
RaTTuS
Re: Use a RPi3 with 5.5V
Fri Nov 24, 2017 9:42 am
5.5V is out of spec , 5.25V is max, YMMV but the polyfuse will blow,
what is wrong with supplying a correct voltage level?
Covfefe
sora03
Fri Nov 24, 2017 10:07 am
Hello
I am currently powering my Pi 2B to 5.7V since it is powering a hard drive (2.5" SATA-USB). I use the MP1584 regulator, to test power I use the program (rpi-burn hosted at https://github.com/ronny-nilsson/rpiburn also test using $ vcgencmd get_throttled) try use those softwares to determine if the Pi is happy at 5v then if it is throttled increase the voltage at a time.
NOTE: using a thick wire for microUSB will mitigate power problems ( a cheap USB to microUSB cable has too much resistance and thin wiring) there is always a voltage drop when the Pi is on-load.
FLOSS enthusiast, Debian user (linux-libre)
joan
Fri Nov 24, 2017 10:14 am
It is certainly possible. It is outside the USB specification of +/- 0.25V but I doubt any device you connect will care. The Pi itself should be okay. I've powered from 5.8V, although I would not knowingly go any higher, get too close to 6V and you may kill the Pi.
drgeoff
Fri Nov 24, 2017 5:08 pm
That is nonsense on two counts.
1. The Broadcom chip gets throttled when it gets too hot. Increased voltage does not mitigate that.
2. The RPi has onboard voltage regulators supplying the Broadcom chip. Increasing the voltage of the 5 volts supply to the board does not significantly increase the voltages applied to the chip.
sora03
Sat Nov 25, 2017 5:38 am
1. the throttling that I refer is when the RED LED blinks indicates insufficient voltage (<4.65V) not the CPU temp
2. yes but the USB peripherals will reduce the voltage (USB WiFi,USB HDD, USB 3G modem if not plugged into Powered USB Hubs)
drgeoff
Sat Nov 25, 2017 9:22 am
No-one except you refers to the red LED blinking as throttling. Everyone except you knows throttling refers to the CPU speed.
If the voltage drops under load, then either the power supply is deficient or the connecting wires have too much resistance. Increasing the power supply voltage is not the way to remedy those.
davidcoton
Sat Nov 25, 2017 10:19 am
drgeoff wrote: No-one except you refers to the red LED blinking as throttling. Everyone except you knows throttling refers to the CPU speed.
Except that, IIRC, one of the consequences of detecting low voltage is to reduce the clock (throttle) in an attempt to reduce power consumption. There is of course absolutely no connection with a marginally high supply voltage, which will not induce throttling (because the voltage is NOT low, and the 3V3/1V8 regulators ensure that the SOC does not receive increased voltage, so does not overheat and throttle for that reason).
So, while there is a connection between low supply voltage and throttling, it is irrelevant here.
drgeoff wrote: If the voltage drops under load, then either the power supply is deficient or the connecting wires have too much resistance. Increasing the power supply voltage is not the way to remedy those.
Increasing the supply voltage while remaining in spec may mitigate cable losses -- even the official PSU has an above nominal voltage for that reason.
It is poor practice to raise the supply voltage above the spec maximum (5.25V) because of:
  1. measurement uncertainties,
  2. not knowing the exact point at which problems occur,
  3. possibly causing an overvolt if the current consumption drops.
The correct solution is the combination of a properly regulated supply capable of the required current at the correct voltage (4.75V to 5.25V at the Pi input), and a short, thick (=low resistance) USB power cable.
Signature retired
