I am looking to purchase a raspberry pi and am looking at the specs (pi 2, 3 models A and B)
Can I connect to internet and ethernet using model A?
I believe I can using model B.
That confirms what I was trying to say.
Quite often the Pi2 is more expensive than the Pi3. See RS for example:
interesting or some reason the Pi 2 is low price and 3 is high price that is sold by RS on my country.jahboater wrote: ↑Tue Nov 21, 2017 7:23 amQuite often the Pi2 is more expensive than the Pi3. See RS for example:
Pi2
http://uk.rs-online.com/web/p/products/ ... lsrc=aw.ds
Pi3
I "built" (in the sense of, soldered in GPIO pins, added a 3.5" display and configured the system) an electronic name badge. It was originally a Pi0, but I changed to a Pi0W, config'd as an access point so that one can connect and log in over WiFi to make adjustments like backlight setting all without having to know or control a local wireless LAN. So there is a use for a Pi0W.
Yep many, many uses for the Zero W but unless you really really know your stuff it is the hardest to use.So there is a use for a Pi0W.
Even without considering bare metal, the Pi0 and Pi0W are very poor choices for beginners. Much better to start with a Pi3B (or a Pi2B if WiFi/BT isn't needed). I have 2 Pi0s in use. One is an NTP server where I used a Pi0 because I could. The other was the prototype name badge with the Adafruit display. Plus the previously mentioned Pi0W. But I've been using Pis since shortly after launch (took about 3 months to get my first one) so the purely Pi stuff isn't new to me. Being a retired programmer who majored in EECS (back when rocks were soft), programming, unix/Linux and soldering are also familiar skills. I don't even begin to think the average Pi buyer starts out with that sort of background.Gavinmc42 wrote: ↑Fri Nov 24, 2017 4:49 amYep many, many uses for the Zero W but unless you really really know your stuff it is the hardest to use.So there is a use for a Pi0W.
There is a firmware blob for the VC4 but there is another one for the WiFi/BT chip.
Not sure, has anyone baremetaled the WiFi chip?
Easier to use A+ with dongle
