natxo
agetty cpu ussage
Mon Nov 13, 2017 11:06 am
Hello
What its "agetty" and why its eating my cpu?
RaTTuS
Re: agetty cpu ussage
Mon Nov 13, 2017 11:38 am
it's an alternative getty
which is a get tty bascially how you log in ,
as that one is running as root a couple of questions
have you opened your pi up to access from the internet and do you have the default username / password still in place?
what are you running on your pi ?
Covfefe
natxo
Mon Nov 13, 2017 11:55 am
No im running my pi on a private network, and i changed my password.
My pi its running a custom app called "gestorTurnos", i was checking how much memory my app use and saw that. i have a PSU board connected and another i2c device. And im running my app from desktop if that matters
Its anything i can check?
PeterO
Mon Nov 13, 2017 11:57 am
What does running the command below produce :
ps lax | grep getty
PeterO
RaTTuS
Mon Nov 13, 2017 11:58 am
your running gestorTurnos as root and that is what is taking up all the cpu ...
Covfefe
natxo
Mon Nov 13, 2017 12:24 pm
ps lax | grep getty
PeterO
Attached an screenshot
RaTTuS wrote: your running gestorTurnos as root and that is what is taking up all the cpu ...
Yes, thats because im sending a hearbeat from y app to the rpi watchdog and if not root i can not write to /dev/watchdog
Im doing that wrong?
RaTTuS
Mon Nov 13, 2017 12:27 pm
1) post your code
2) install pastebinit
i.e.
sudo apt-get update && sudo apt-get install pastebinit
then sue that to post text - don't do screenshots - they are hard to read....
like
ps axOT | pastebinit
Covfefe
PeterO
Mon Nov 13, 2017 12:30 pm
Try turning off the login on ttyAMA0 with raspi-config.
PeterO
KLL
Mon Nov 13, 2017 12:31 pm
sudo apt-get update && sudp apt-get install pastebinit
RaTTuS
Mon Nov 13, 2017 12:33 pm
and fixed ;-p
Covfefe
natxo
Mon Nov 13, 2017 12:40 pm
1) post your code
i.e.
like
What code are do you refer, the class i made for watchdog its
https://gist.github.com/natxopedreira/6 ... 43c6cd4b99
And the pastebinit result of ps lax | grep getty
http://paste.debian.net/995444
natxo
Mon Nov 13, 2017 1:51 pm
PeterO
I run raspi-config and said no to:
+ would you like a login shell to be accesible over serial?
+ would you like the serial hardware port to be enabled?
reboot, try again and still agetty its eating my cpu.
natxo
Mon Nov 13, 2017 1:59 pm
Also if i stop my app and run top i still see "agetty" eating my cpu
natxo
Re: agetty cpu ussage [SOLVED]
Mon Nov 13, 2017 6:51 pm
Hello
Previously i disable the console on ttyAMA0 with raps-config... and get the same result.
But.... i was able to get rid of this agetty high cpu with this :D :D
sudo systemctl stop [email protected]
sudo systemctl disable [email protected]
Thanks to all for your help, community its great !!!
RaTTuS
Tue Nov 14, 2017 8:13 am
umm interesting ,
do you have anything plugged into the GPIO ports of the RPI ?
Covfefe
natxo
Wed Nov 15, 2017 2:29 pm
Yep i have two i2c boards connected, not using serial at all
Return to “Beginners”
