Jorge Vargas
problems when starting Node red
Sun Nov 12, 2017 9:30 pm
Someone knows why when starting Node Red, the terminal shows: [error] [tls-config: AWS] Error: ENOENT, no such file or directory '/home/pi/pi_socket/TSRV.cert.pem'
Does someone know how to solve this problem?
My problem started when I installed node-red-contrib-pca9685. Node Red loads the localhost but does not load any node and flow scheme.
KLL
Re: problems when starting Node red
Mon Nov 13, 2017 6:31 am
can you be more detailed about history?
-?- RPI board
-?- OS
-?- project board
-?- install procedure
-?- complete log
pi@RPI3:~ $ node-red-log
Started Node-RED graphical event wiring tool..
13 Nov 13:11:49 - [info]
Welcome to Node-RED
13 Nov 13:11:49 - [info] Node-RED version: v0.17.4
13 Nov 13:11:49 - [info] Node.js  version: v4.8.2
13 Nov 13:11:49 - [info] Linux 4.9.59-v7+ arm LE
13 Nov 13:11:49 - [info] Palette editor disabled : npm command not found
13 Nov 13:11:49 - [info] Loading palette nodes
13 Nov 13:11:56 - [info] Settings file  : /home/pi/.node-red/settings.js
13 Nov 13:11:56 - [info] User directory : /home/pi/.node-red
13 Nov 13:11:56 - [info] Flows file     : /home/pi/.node-red/flows_RPI3.json
13 Nov 13:11:56 - [info] Creating new flow file
13 Nov 13:11:56 - [info] Starting flows
13 Nov 13:11:56 - [info] Started flows
13 Nov 13:11:56 - [info] Server now running at http://127.0.0.1:1880/
