Hi'
Im trying to set up a logitech c270 cam on my pi3. i have Ethernet cable connected to the pi, But would like wlan as the final result.
1) ive downloaded motioneyeos
2) put it on sd card using etcher
3) booted the pi into the setup and all done
this is where im stuck
4) its at the login stage and tells me my ip is 192.168.1.78
this is not true because all my ip address are 192.168.66.etc so i can't connect to the pi on that ip and if i try and simply type 66 in place of the 1 then that don't work ether.
i need to some how tell the pi im on 192.168.66 and not 192.168.1 why could the pi not get this info from the router at the beginning? after all it is connected to it via lan cable.
maybe im missing the point here but i cant do anything with this until i get the ip problem sorted, Any help would be appreciated.
