Stop infinite loop from startup console
Posted: Tue Nov 07, 2017 4:02 am
by profbit
I’m having trouble in stopping infinite loop on startup console.
when I tried ctrl c or ctrl z or alt. it shows weird text. What is the command so that I can get back to the command line [[email protected]:] part? thanks
Re: Stop infinite loop from startup console
Posted: Tue Nov 07, 2017 7:40 am
by KLL
to repair ?what? you have messed up
-a- you could try to login remote by SSH if that is enabled
-b- use that SD in card reader and a working system SD
if you not find the reason for that you anyway need a new setup
Posted: Tue Nov 07, 2017 7:50 am
by profbit
no no. the script is running then I can’t stop it since it’s on startup. im looking for a command to kill or stop the process
Posted: Tue Nov 07, 2017 7:59 am
by KLL
does
[ALT][F2]
give you anything?
Posted: Tue Nov 07, 2017 8:06 am
by profbit
does
[ALT][F2]
give you anything?
If I remembered it correctly, it shows me tty2 login and I’m a bit scared on what it is. I don’t even know the pw.
Posted: Tue Nov 07, 2017 8:08 am
by profbit
does
[ALT][F2]
give you anything?
btw my startup screen is console.
Posted: Tue Nov 07, 2017 8:57 am
by KLL
again: how you get into that situation?
did you try autostart some music even you not login desktop.
if you know what files you changed, change them back by edit them while SD in cardreader.
Posted: Tue Nov 07, 2017 9:18 am
by sora03
if you have a linux pc/laptop you can mount the microsd and edit files. /etc/rc.local
the weird symbols maybe because of the locale settings
Posted: Tue Nov 07, 2017 9:21 am
by rpdom
does
[ALT][F2]
give you anything?
Unless you have changed things, or are not using Raspbian, the login name is pi and the password is raspberry.
Posted: Tue Nov 07, 2017 10:01 am
by profbit
I’ve edited the .bashrc file then started running a script on startup so that happens. is it possible to edit the .bashrc file by connecting sd card to pc?
Posted: Tue Nov 07, 2017 10:13 am
by rpdom
Not on Windows, but you can do it with Linux. If you don't have a Linux PC you could boot most PCs from a Linux Live USB stick, or put another copy of Raspbian on a spare SD card and use your Pi.
Posted: Tue Nov 07, 2017 10:22 am
by profbit
how about filezilla?
Posted: Tue Nov 07, 2017 10:28 am
by KLL
linux pc easy, windows difficult
why not setup a second SD / i recommend to have a MASTER setup SD for this kind of problems and
for new setups using / update / upgrade / sd card copy /
Posted: Tue Nov 07, 2017 10:37 am
by sora03
if you can access the pi using ssh over network you can edit the file using sftp(ssh). you can get a linux live iso for 50mb just search.
