pi@raspiP3B16Gb:~ $ uname -a
Linux raspiP3B16Gb 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
pi@raspiP3B16Gb:~ $ gpio readall
+-----+-----+---------+------+---+---Pi 3---+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 1 | ALT5 | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT5 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | ALT0 | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | ALT0 | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | ALT0 | 0 | 23 || 24 | 1 | OUT | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | OUT | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | IN | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 0 | IN | GPIO.29 | 29 | 21 |
I like this one better.
import RPi.GPIO as GPIO
GPIO.setmode (GPIO.BCM)
GPIO.setup (36,GPIO.OUT)
GPIO.output (36,1)
import time
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(19,GPIO.OUT)
GPIO.setup(21,GPIO.OUT)
GPIO.setup(23,GPIO.OUT)
GPIO.setup(22,GPIO.OUT)
GPIO.setup(24,GPIO.OUT)
GPIO.setup(26,GPIO.OUT)
def rForward():
GPIO.output(21,1)
GPIO.output(19,0)
GPIO.output(23,1)
def lForward():
GPIO.output(24,1)
GPIO.output(22,0)
GPIO.output(26,1)
def rBackward():
GPIO.output(21,1)
GPIO.output(19,1)
GPIO.output(23,0)
def lBackward():
GPIO.output(24,1)
GPIO.output(22,1)
GPIO.output(26,0)
def allStop():
GPIO.output(21,0)
GPIO.output(24,0)
rForward()
lForward()
time.sleep(2)
allStop()
time.sleep(0.5)
rBackward()
lBackward()
time.sleep(2)
allStop()
looks like you are still confusing board and bcm modes.
GPIO.setmode(GPIO.BOARD)Code: Select all
GPIO.setmode(GPIO.BCM)
