ChefPi
Raspberry Pi 3 Wifi connected but no internet
Thu Oct 26, 2017 3:29 pm
My Raspberry Pi 3 kit has built in wifi. My network is selected and it shows that the Wifi is connected, yet I am not connected to the internet. Upon a browser search I get ERR_NAME_RESOLUTION_FAILED. Please help! And I have not used an ethernet cable to connect at any point.
HawaiianPi
Re: Raspberry Pi 3 Wifi connected but no internet
Thu Oct 26, 2017 6:19 pm
What OS are you running?
How did you install it?
How did you connect to your network?
What edits or changes have you made to the OS?
Fri Oct 27, 2017 4:09 pm
What do you get from a wpa_cli status command?
This is a doctor free zone.
sora03
Fri Oct 27, 2017 11:23 pm
ERR_NAME_RESOLUTION_FAILED means that theres no DNS server configured. are you using CLI or GUI? try to cat /etc/resolv.conf
to get an ip address you nees to configure the /etc/network/interfaces
also try to get a dhcp lease; # dhclient wlanX
change wlanX to yojr wifi interface name. sudo ifconfig -a
FLOSS enthusiast, Debian user (linux-libre)
DirkS
Sat Oct 28, 2017 12:05 am
That depends on OS + version.
On RPF / Official Raspbian Jessie & Stretch it's completely wrong...
And sudo is not necessary to run ifconfig.
sora03
Mon Oct 30, 2017 2:56 am
sudo may be needed to run ifconfig since debian 9 refuses to exec if not using sudo. im using the raspbian stretch 9.1. there are configuration on how to reconnect to internet everywhere so just choose which you prefer
arurama
Sat Nov 04, 2017 1:19 pm
i also have the same problem.
Following info after wpa_cli status
[email protected]:~ $ sudo wpa_cli status
Selected interface 'p2p-dev-wlan0'
wpa_state=DISCONNECTED
p2p_device_address=ba:27:eb:89:7f:05
uuid=143d116a-3086-59f8-8010-6b1bb34eb1fb
stainlessray
Wed Jan 10, 2018 2:54 am
Same issue. Came out of the blue. Worker when I left the house. Didn't when I returned 8 hrs later.
Thu Jan 11, 2018 12:57 pm
Your wireless lan isn't associated with your access point. wpa_cli status should get something like
Selected interface 'wlan0'
bssid=30:91:de:ad:be:ef
freq=2427
ssid=redacted
id=4
mode=station
pairwise_cipher=CCMP
group_cipher=TKIP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ip_address=192.168.3.14
address=b8:27:eb:99:aa:bb
uuid=ffffeeee-aaaa-bbbb-cccc-99992222dddd
FatBastard
Sun Feb 11, 2018 3:01 am
Wpw This all has me so LOST.
ip route returns
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.100 metric 303
wpa_cla status returned
failed to connect to non global....
This is all vie ethernet cable to the router.
Roaabkh
Tue Feb 27, 2018 11:01 pm
Hello
ChefPi wrote: My Raspberry Pi 3 kit has built in wifi. My network is selected and it shows that the Wifi is connected, yet I am not connected to the internet. Upon a browser search I get ERR_NAME_RESOLUTION_FAILED. Please help! And I have not used an ethernet cable to connect at any point.
I am using Raspberry Pi 3 with latest Rasbian Stretch and I just started having this problem.
I noticed that it happened right after doing sudo apt-get install and sudo apt-get upgrade so could it maybe be an issue with the latest update?
DougieLawson wrote: What do you get from a wpa_cli status command?
This is the result of the command wpa_cli status:
address=ba:27:eb:cf:fa:be
uuid=acb971c9-406a-5688-a8a1-bb04e0934f19
I've been trying different solutions
I added the following in the file /etc/network/interfaces
auto lo
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
iface wlan0 inet dhcp
wpa-ssid "my_netwrok_name"
wpa-psk "my_network_password"
After saving, I can open websites and the problem seems to be solved. However, after reboot I get "No wireless interfaces found" and I am not able to scan or connect to networks until I undo what I did above and reboot again. This is not a practical solution for me anyway because I want the ability to connect to different wifi networks.
Can anyone help me?
Thanks in advance for the support.
milking
Mon Mar 12, 2018 12:14 pm
Hey guys, similar issues with OS Jessie
I have dhcpcd.conf setup with my static IP's, which are being issued correctly by both wifi and ethernet
Ethernet works fine, internet connection all good
Wifi connects fine, internet connection not all good
wpa_cli status gives me the following;
ssid=TPG FA8D
id=0
mode=station
group_cipher=CCMP
key_mgmt=WPA2-PSK
wpa_state=COMPLETED
ip_address=192.168.1.20
Have re-booted, changed settings etc, but cannot get the wifi to give me internet access, anything I am missing?
I have the following in /etc/network/interfaces;
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
I am going to try restoring my OS, and see what happens from default
