Hi All
So I have found many articles online regarding the use of Solenoid Valves, but since I am not an electrical engineer, can someone please explain to me something:
If I were to use a Normally Closed solenoid valve and apply the current it needs, that it will open fully? Do solenoid Valves only have two settings i.e Full Open or Full Closed...there is no way to get them to only open 30% (this is only an example) ? If this is the case that they can only open and close, what would you recommend I use to open a valve certain increments?
