lerner
Firefox won't install - here or mozilla?
Sun Oct 22, 2017 2:11 am
Folks,
After a long time rebuilding a couple of machines I have the problem of Firefox not wanting to install.
Following this:
sudo apt-get purge firefox
echo 'deb http://q4os.org/qextrepo q4os-rpi-firefox-cn main' | sudo tee /etc/apt/sources.list.d/qextrepo.list
wget -nv -O- http://q4os.org/qextrepo/q4a-q4os.gpg.pub | sudo apt-key add -
sudo apt-get update
sudo apt-get install firefox
It has worked many times on many machines I have bulid.
I get this.
sudo apt install firefox
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 firefox : Depends: libhunspell-1.3-0 (>= 1.3.3) but it is not installable
E: Unable to correct problems, you have held broken packages.
So is it Mozilla's "problem" of a Ras Pi "problem"?
Friendly question.
asandford
Re: Firefox won't install - here or mozilla?
Sun Oct 22, 2017 3:34 am
No, it's your problem.
You uninstalled the pi version and are installing a version built for a different OS.
lerner
Sun Oct 22, 2017 7:16 am
Gee, you got out on the wrong side of the bed today.
Ok.
I installed it on a different VERSION of the O/S.
Which to me is different to: a different O/S.
Note: VERSION.
Anyway, lesson remembered.
k-pi
Sun Oct 22, 2017 11:40 am
Either the package is unavailable/not built yet, or you have it pinned.
asandford
Mon Oct 23, 2017 12:11 am
Ok.
Note: VERSION.
If you don't understand that "different VERSION of the O/S" are actually different, then there's no hope. The word you want is Distributions, and the supported one is not the one you're asking about.
Note: Distribution
Good luck with your problem, I'm out.
