nunocv
python and crontab
Sat Oct 21, 2017 1:29 am
i'm trying to get the startup time of my raspi, the time that i turn it on.
i create this python script called 'boot_time.py'
from time import strftime
with open("/home/pi/monitor/boot_time.txt", "w") as log:
  log.write(strftime("%d-%m-%Y,%H:%M:%S"))
the code works ok if execute the python file. it register the date and time that i executed the script
so i created a crontab entry so the script would run on boot
so i executed
crontab -e
and added the following line
@reboot python /home/pi/monitor/boot_time.py &
the thing is that on very first boot it doens't work
it only works when i reboot the system
hope that one of you guys can help me figure out what's wrong
pcmanbob
Re: python and crontab
Sat Oct 21, 2017 1:08 pm
Hi.
So using a pi2b running Jessie lite with a wired connection and a fixed IP on the pi, ran your code using the cron line
@reboot python /home/pi/boot_time.py
and it works perfectly on reboot and a cold start.
So then I tried it with no network connection and it still works but you just get the saved time set by the fake HW clock.
So I don't see why it wont work for you may be some more details which OS and what network connection would help with us trying to reproduce your problem.
Edit.... repeated using same pi but using stretch lite and a fixed IP on the pi same results still works ok.
rpdom
Sat Oct 21, 2017 2:53 pm
crontab -e
You don't need the "&" on a line in crontab. The code always runs in the background.
To diagnose errors when running you can direct the output to a file like this:
@reboot python /home/pi/monitor/boot_time.py >/tmp/myprog.log 2>/tmp/myprog.err
That should create two files when the cron job triggers. /tmp/myprog.log, which has any standard output from the script and /tmp/myprog.err which will contain any error mssages.
nunocv
Sun Oct 22, 2017 12:39 am
thanks for your reply guys.
pcmanbob you said that:
what does this mean?
rpdom i removed the '&' and added the 'log' and 'err', but they both came clean
i think the problem may be related to what pcmanbob said about 'fake HW clock', but i need the learn the real meaning of this
rpdom
Sun Oct 22, 2017 4:55 am
Unlike most computers, the Pi doesn't have an onboard clock with battery power. This means that when it is switched off it forgets the time and date completely.
To get around this the Pi uses two methods.
One is to set the time from an internet time server when it starts up. That only works when it has an internet connection.
The other is to use a program called fake-hwclock which logs the current time in a file every hour (at 17 minutes past the hour, usually), and also during shutdown. When the Pi starts up it reads that file and sets the clock to that time. This means that the time will be wrong, but it will at least be showing as later than the shutdown time so timestamps won't suddenly jump back in time.
The file is /etc/fake-hwclock.data and you can read the contents with the cat command
pi@raspi3 ~ $ cat /etc/fake-hwclock.data
2017-10-22 04:17:01
pcmanbob
Sun Oct 22, 2017 9:33 am
Try this.
add a delay to your cron line so that the pi waits for 1 min before running the python program just to see if it works then.
@reboot sleep 60 && python /home/pi/monitor/boot_time.py >/tmp/myprog.log 2>/tmp/myprog.err
this might reveal if its some thing that is not ready when you are calling the python program.
nunocv
Sun Oct 22, 2017 3:32 pm
this is owesome, i didn't know that the pi don't have an internal clock, and the fake clock is indeed a great method to try to overcome this problem.
my script was actually working, but it was executed before my raspi (which is connected to the network) updated the time online.
so now i added the delay on crontab
@reboot sleep 60 && python /home/pi/monitor/boot_time.py >/tmp/boottime.log 2>/tmp/boottime.err
thanks you guys
last question, how do mark this topic as solved?
Sun Oct 22, 2017 3:48 pm
If you're time critical then create a systemd service sudo nano /etc/systemd/system/python_thing.service
[Unit]
Description=python thing
DefaultDependencies=no
After=local-fs.target time-sync.target
[Service]
Type=oneshot
ExecStart=/home/pi/monitor/boot_time.py
Edit your boot_time.py program and add
#!/usr/bin/python
as the first line in the program.
make your python program executable
chmod 755 boot_time.py
no need to use python boot_time.py to run it after that.
Make your service file active
sudo systemctl enable python_thing
scruss
Mon Oct 23, 2017 3:44 am
If you're time critical then create a systemd service …
Better yet, create a user systemd service. Save this as ~/.config/systemd/user/boot_time_log.service:
[Unit]
Description=boot time log
[Service]
Type=oneshot
[Install]
WantedBy=default.target
then enable it with:
systemctl --user enable boot_time_log.service
Look Ma, no sudo! Also no weird root-owned files in your home folder too!
Pronouns: he/him
Mon Oct 23, 2017 10:57 am
Thanks Stewart, I've learned a new trick.
Didn't know about --user.
scruss
Mon Oct 23, 2017 3:26 pm
Thought you might like that, Dougie. systemd keeps on giving!
Pronouns: he/him
nunocv
Wed Nov 01, 2017 2:56 am
you're blowing my mind scruss, this looks great
but when i tryed to enabled it, i receve this error
Failed to execute operation: No such file or directory
to directory you mention does not exist (there was no directory systemd inside ~/.config
so i manually created it
can you give me a step by step?
scruss
Wed Nov 01, 2017 3:42 am
sure:
mkdir -p ~/.config/systemd/user
then create the ~/monitor/boot_time.py file and make it executable
now save the service file and enable it like I explained.
Pronouns: he/him
Return to “Beginners”
