DPaul
Azerty prob [solved]
Thu Oct 19, 2017 7:52 am
Booted up pi3 for the first time, it works !
Except....
In the preference menu, keyb/mouse, i changed the keyb to Azerty.
Doing the test with "raspberry" it indeed puts the a in the right place (not "rqspberry")
I wanted to test changing user (via Log out), and since i only have one user (default pi),
i log back in with the password "raspberry". Only it has not remembered the Azerty keyboard,
so i have to accomodate for querty keys.
Once logged in, i checked the keyb/mouse settings immediately, but those were still happily on azerty.
Why the login probs?
(If it's a known prob, sorry, but the forum search does not seem to work at the moment "very busy")
thx,
Paul
Re: Azerty prob
Thu Oct 19, 2017 9:53 am
How have you set your AZERTY keyboard?
sudo dpkg-reconfigure keyboard-reconfiguration
or
sudo nano /etc/default/keyboard
change
XKBLAYOUT="gb"
to
XKBLAYOUT="fr"
Have you rebooted after changing the layout?
Note:The use of baseball bats for educational purposes is completely disallowed on this forum.
DPaul
Re: Azerty prob
Thu Oct 19, 2017 10:01 am
OK, i just changed it via the menu / preferences.
Said nothing about rebooting.
I'll see what happens next time i power up.
Will let you know.
thx,
Paul
DPaul
Re: Azerty prob
Fri Oct 20, 2017 9:23 am
No succes yet !
Started again, finding my preferences intact, as i set them, Azerty keyboard.
In command mode, i was able to enter the long command to create a new user "sudo useradd -m -G ...etc etc "
clearly with a azerty character layout.
I even logout-rebooted.
All is well EXCEPT when i change accounts, and i want to go to "Pi, pw = raspberry", it keeps on typing "rqspberry".
That is the moment when the azerty keyboard setting is not respected.
Not that it is a big issue, but every account and password that i create may have the prob if i don't watch out. (if i don't find a solution.)
thx,
Paul
B.Goode
Re: Azerty prob
Thu Oct 26, 2017 3:49 pm
The Raspberry Pi Foundation documentation about configuration of Raspbian suggests using the raspi-config utility. I don't think that in any of your posts you have mentioned doing that?
https://www.raspberrypi.org/documentati ... isation.md
DPaul
Re: Azerty prob
Sat Oct 28, 2017 6:22 am
Raspi-config utility ?
No idea what that is, but i will find out and let you know. :-)
Paul
DPaul
Re: Azerty prob [solved]
Sat Oct 28, 2017 7:38 am
Thanks B.Goode, very simple solution, took me a couple of seconds to put it right.
Passwords are in azerty now.
Paul
Return to “Beginners”
