lerner
Problems compiling code. QT stufff
Mon Oct 16, 2017 9:25 pm
I am trying to be brief as possible but not so brief, no help will be possible.
Back in about April this year I downloaded QT5 for the RPI.
At that time I was running Jessie.
It downloaded and I compiled it.
Then, with it compiled, I then compiled some source and the program worked/was compiled.
Alas other things were a problem and I still couldn't use the program.
In the mean time I upgraded to strech - AFAIK anyway.
The program was re-released and the new code was there to download.
I downloaded it and went through the steps. But it wouldn't work.
This is what happens:
qmake ../Moolticute.pro
qmake: could not exec '/usr/lib/arm-linux-gnueabihf/qt4/bin/qmake': No such file or directory
That had me stumped until I realised that it was pointing to QT4 and not QT5!
So I don't get/understand how/when QT4 got on the system and that if I installed QT5 back in April how did QT4 get into the equation?
Yes, maybe it was there all the time, and I needed QT5, but still..... Why did it work then and not now?
Maybe the update from Jessie to Strech?
So how do I set the system to understand it has QT5?
Thanks in advance.
piras77
Re: Problems compiling code. QT stufff
Tue Oct 17, 2017 7:18 am
Maybe this helps: https://stackoverflow.com/questions/397 ... by-default
(There may be several Qt installations on your system; you can select among them by env variable, symlink or direct call.)
lerner
Tue Oct 17, 2017 9:41 am
Thanks looking into it now.
Got and installed qt5-default.
Seems to have moved me forward one square.
Now I'm getting this error:
( test -e Makefile.daemon || /usr/lib/arm-linux-gnueabihf/qt5/bin/qmake /home/pi/Downloads/moolticute-master/daemon.pro -o Makefile.daemon ) && make -f Makefile.daemon
Project ERROR: Unknown module(s) in QT: websockets
Makefile:38: recipe for target 'sub-daemon-pro-make_first' failed
make: *** [sub-daemon-pro-make_first] Error 3
AARRGGHH!
Seems I may have to install/get the latest version.
KLL
Tue Oct 17, 2017 10:50 am
lerner
Tue Oct 17, 2017 11:16 am
Thanks much.
I shall have to start asking there.
Reading their last solution it now gives a new weirder error.
I'll take it up there.
Thanks though and sorry I didn't go there at the start.
I wasn't sure if it was a RasPi problem, compiler problem or what.
Appreciated.
