FelixPI
Use of older monitor with Raspberry PI?
Mon Oct 16, 2017 8:38 am
Hi there,
I have an older monitor, LG Flatron L1718S, which I plan to use with a raspberry computer. The monitor is 1280x1024 pixels and has only VGA connectivity. I looked for a HDMI-VGA cable/adaptor, found a cable but the vendor's site said that the cable works only with HD monitors (1366x768 pixels) and only if the laptop/computer has a dedicated graphics card!! Is that true?? According to your experience, could I use that monitor with a HDMI-VGA cable and a raspberry computer? Thank you, Felix
drgeoff
Re: Use of older monitor with Raspberry PI?
Mon Oct 16, 2017 9:36 am
A passive cable will not work. You need an adaptor with active electronics inside and preferably its own power supply.
Post a link to the item.
FTrevorGowen
Mon Oct 16, 2017 11:24 am
drgeoff wrote: A passive cable will not work. You need an adaptor with active electronics inside and preferably its own power supply.
+1 and, FWIW, (and to compare with) here are links to the four HDMI-to-VGA adapters I've used/tested and, for ref./info. some (older) notes on the use of such with a few VGA displays:
http://www.cpmspectrepi.uk/raspberry_pi ... erter.html
http://www.cpmspectrepi.uk/raspberry_pi ... rter2.html
http://www.cpmspectrepi.uk/raspberry_pi ... Audio.html
http://www.cpmspectrepi.uk/raspberry_pi ... tings.html
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
W. H. Heydt
Mon Oct 16, 2017 4:02 pm
Pity it's only got VGA. I have a 19" Flatron 1280x1024 that I use with Pis. It has DVI input in addition to VGA. (And I *love* the name of the monitor line...)
gkaiseril
Mon Oct 16, 2017 6:59 pm
I am using =https://www.insigniaproducts.com/pdp/N ... GA adapter without any power being applied to it with no problems. The adapter does have a USB C port for power input port for the computer does not supply the requisite HDMI power. This does not appear to be an issue with the Pi 3.
DirkS
Mon Oct 16, 2017 7:29 pm
Not Found
The requested URL /forums/=https://www.insigniaproducts.com/pdp/NS ... 417Insigna HDMI to VGA adapter was not found on this server.
FelixPI
Tue Oct 17, 2017 6:01 am
Thank you guys for your input! I'll buy one of these adapters. Felix
FelixPI
Tue Oct 17, 2017 6:07 am
Not Found
The correct link is https://www.insigniaproducts.com/pdp/NS-PG95503/1577417
drgeoff
Tue Oct 17, 2017 7:53 am
Not Found
Over-priced and no audio output?
Return to “Beginners”
