tony1812
USB 3.0 is backward compitible to Pi?
Sun Oct 15, 2017 5:15 pm
Hello, I ordered a Sata to USB adaptor for my pi 3 StarTech USB 3.0 To 2.5 SATA III Hard Drive Adapter Cable / UASP - SATA To USB. Afterward I realized it is for USB 3.0. I understand that Pi 3 has only USB 2.0. Now I wonder if this USB 3.0 is backward compitible to Pi, should I cancel the order? Thanks
gkaiseril
Re: USB 3.0 is backward compitible to Pi?
Sun Oct 15, 2017 5:24 pm
USB 3.0 devices should be compatible if it follows the USB standard. Your throughput will be limited to the 2.0 specification so you will not get the full benefit of the USB 3.0 device. If you have any doubts, you should contact the seller or manufacturer for confirmation. It is possible Windows 8 or older OS could have an issue.
My Toshiba Canvio USB 3.0 drive works perfectly in USB 2.0 compatibilty mode.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
jahboater
Sun Oct 15, 2017 5:58 pm
My USB 3.0 GiGe ethernet adaptors work fine too.
alphanumeric
Sun Oct 15, 2017 7:26 pm
Speed wise it should be backward compatible, and just run at USB 2 speed. Power, namely current draw may be an issue though. If the drive wants or needs more current than the Pi can supply via the USB port it may not work reliably, or not at all. If you adapter has its own power supply it won't be an issue though.
W. H. Heydt
Sun Oct 15, 2017 8:15 pm
I've been using USB 3 to SATA adapters for at least a couple of years and they work fine with Pis. In addition, if some time in the future there is a Pi with native USB 3...you'll be all set for faster mass storage access.
Return to “Beginners”
Who is online
Users browsing this forum: No registered users and 35 guests
