Borner
installing PHP requires apache?
Mon Oct 08, 2012 8:07 pm
I like to setup an webserver using nginx. For my project I need some php modules, like this:
apt-get install php5 php-xml-serializer php5-gd php5-sqlite
Running this apt-get command, apt find some requirements:
  apache2-mpm-prefork apache2-utils apache2.2-bin apache2.2-common
  libapache2-mod-php5 libapr1 libaprutil1 libaprutil1-dbd-sqlite3
  libaprutil1-ldap libonig2 libqdbm14 php-pear php-xml-parser php5-cli
  php5-common ssl-cert
As you can see apache is selected!?!
After installing those packages, the apache webservers starts automaticly.
Does anybody know, why?
Is there a way to avoid apache installation?
Maybe by installing ngxinx and php5-fpm before installing php5?
Thank you!
vladb
Re: installing PHP requires apache?
Mon Oct 08, 2012 8:17 pm
It is possible. I use this for cli-only install
apt-get install php5-cli php5-common php5-fpm php5-cgi php5 php-pear php5-mcrypt php5-mysql php5-gd php-apc memcached
Borner
Mon Oct 08, 2012 8:28 pm
..this menas, the package php is the one who needs the apache package?!
//EDit: oh no.. after re-reading your post I see, you also installed the package php5
Does installing php-cli results in the effect, that apache2 is not needed? Strange!
Borner
I have got it.
Mon Oct 08, 2012 9:13 pm
It lookes like the solution is to install the webserver befor installing php.
In my case: if I install nginx before php, so the php installation does not install apache anymore.
wow.
penguintutor
Wed Oct 10, 2012 2:04 pm
This is explained looking at the PHP5 package information.
http://packages.debian.org/sid/php5
This package is a metapackage that, when installed, guarantees that you have at least one of the four server-side versions of the PHP5 interpreter installed.
php5-cli has less dependencies and doesn't need a web server installed.
Borner
Fri Oct 12, 2012 12:14 pm
okay.. i see. Thank you, that was an important information for me!
Return to “Beginners”
