Scripting Advice
Posted: Mon Oct 09, 2017 11:27 am
by kiteboywales
Hi all
I have a raspberry pi w thats taking a photo when the pi starts and placing the jpg in /home/pi/images
That script seems to be working ok when the pi boots
What I would like to do is have another script that checks this folder and then ftps all the jpgs to a server
Im using the following to do that at the moment using ncftpput
#!/bin/bash
sleep 5
ncftpput -F -DD -S .tmp -u ******** -p ******* myserver.com /TestCamera /home/pi/images/*.jpg
echo uploading photos please wait......
while true ; do ./home/pi/ftpupload.sh & sleep 5; done
When running this by doing ./ftupload.sh from the command line it seems to upload any images in that folder and delete them when complete...great - exactly what I would llike
When there are no jpgs in that folder I get an error "/home/pi/ftpupload.sh: No such file or directory" and when new jpgs go i there even though the script re-runs every 5secs it doesnt pick anything new up
What am I doing wrong and what would be the best way start this on boot??
Newbie here so go slow please
Thanks for any advice
Re: Scripting Advice
Posted: Mon Oct 09, 2017 12:31 pm
by Martin Frezman
I think it would be simpler to use a shared directory method instead of FTP.
Easiest is to make the directory on the server (which I'm guessing is either Windows or Linux) shared, then have your picture taking routine write files directly to that directory.
BTW, I've used FTP a lot back in the day - it had its place - and I've used the NCFTP tools a lot too, but not in a long time. It doesn't seem to be necessary anymore.
Posted: Mon Oct 09, 2017 1:11 pm
by pcmanbob
You could do a check first to see if there are any files in the directory and only run your upload part of the script if there are any.
some thing along the lines of this
#!/bin/bash
sleep 5
file="/home/pi/images/*.jpg"
if [ -e "$file" ]
then
 else
	echo "$file not found
untested code.
Posted: Mon Oct 09, 2017 1:47 pm
by kiteboywales
Thanks all - will try that bit of code instead
Has to be FTP im afraid.......... as far as I know anyway - its a remote linux server
Im sure you could dropbox it or something similar but theres scripts on that server checking for files too
FTP is a standard although albeit not the most secure
Will give that a go
Thanks again
Posted: Mon Oct 09, 2017 2:06 pm
by Martin Frezman
Is SSH an option?
As you say, FTP is completely insecure - as well as hard to implement (if this comment makes no sense to you, just ignore it).
If SSH is usable, then there are several possibilities there - including (best) sshfs.
