e-student
Raspberry Pi as PLC over profinet
Thu Oct 05, 2017 6:05 pm
Hi all,
I have Rasp Pi 3 Model B and need to do the control of asynchronous drive (SIEMENS) which is connected to control unit (SIEMENS) and I have Ethernet cable which I should connect to Raspberry Pi. I use software CODESYS Control for Raspberry Pi SL, and I have problem to in a communication between Pi and control unit. Please suggest is this project possible, do I need any additional hardware? I haven't seen projects which connect Siemens hardware with Codesys software, could this cause a problem?
Thank you in advance!
ranpitime
Re: Raspberry Pi as PLC over profinet
Fri Oct 06, 2017 5:42 pm
the CODESYS plc on Raspberry PI could be
ProfinetController or Profinet Device... so you have the choice how to connect to your Siemens control unit.
BR
ranpitime
