raspberrynewbB
Not getting any output from MCP3008 [solved]
Mon Oct 02, 2017 6:55 am
Hello there,
I have wired the MCP3008 according to this tutorial: https://learn.adafruit.com/raspberry-pi ... rs/mcp3008
I have used male-female jumpers to go from the GPIO pins to the breadboard so i know for sure my connections are correct. I wired it to the RPi3 to connect with a software SPI connection.
When I run the tutorial to output reading for the channels, I get only 0 values. To check if the ADC was working I connected a 3v3 cable to one of the analog inputs, expecting to get a 1024 output, which would correspond to 3v3 becasue Vref is 3v3.
Instead I only get 0. In fact, every now and then (rarely but still happens) I get a 1024 output for channels that I don't even have connected to anything?
Can anyone help me?
KLL
Re: Not getting any output from MCP3008
Mon Oct 02, 2017 7:24 am
did you check the correct forum?
piras77
Mon Oct 02, 2017 7:50 am
Well, if you are sure that you did everything right, then, as the only conclusion, something must be broken.
In my experience, this is rarely the case, so you may want to check your setup again.
You may also want to have a look at the datasheet: https://cdn-shop.adafruit.com/datasheets/MCP3008.pdf
Anyway, a good start to analyze your problem is to trace the signals with a logic analyzer (which are less than 10 bucks).
Im sure you will get help here if you provide more information as pictures, actual measurements or traces of the logic analyzer.
BTW: Analog inputs that are not connected may return random values. However, in my experience, they won't toggle between 0V and 3.3V as you describe.
B.Goode
Mon Oct 02, 2017 9:47 am
The gpiozero Python library module installed by default with recent releases of the Raspbian Operating System includes built-in support for the MCP3008 chip.
The sample 'recipe' even includes a wiring diagram.
Perhaps it would be worth trying this alternative solution? If it works it would prove that your MCP3008 chip is functioning and if necessary you could return to the Adafruit example with fresh confidence.
http://gpiozero.readthedocs.io/en/stabl ... entiometer
raspberrynewbB
Wed Oct 04, 2017 12:08 am
thank you all for the suggestions..after some digging i ended up getting it work :D
much appreciated
B.Goode
Wed Oct 04, 2017 8:09 am
For the possible benefit of others who may read this thread in the future could you say a few words about what the problem was, or what the key troubleshooting step was? Was it the wiring, or the coding, or a combination?
Also it is the practice in this forum to now edit the Subject/Title of your initial post to add [Solved] or something similar.
cszalaj
Tue Dec 18, 2018 2:46 pm
Hi, I'm new to RPi projects, and am trying to use the MCP3008 with hardware SPI interface to connect a capacitative moisture sensor.
I believe things to be wired up properly, but I have the same issue as noted here from the previous user, I only see 0 for the channels when i run the sample python that reads the channel output from the MCP3008.
I followed the wiring here for the hardware SPI interface:
Here are pictures of my wiring:
https://drive.google.com/open?id=1Qs8AN ... NSpeiudUJa
https://drive.google.com/open?id=18di_r ... iQ3__Gzxk2
Not sure if this is the most helpful way to provide the info or not, so please let me know what you need to help me out.
Thanks for any suggestions! I'd love to know what the last person did that helped them -
Chris
pcmanbob
Tue Dec 18, 2018 6:59 pm
Chris
Hi.
If you have a read of this thread viewtopic.php?f=28&t=211861
specifically my posts on 24 Apr 2018, 16:31 will give you the correct connections between your pi and the MCP3008 and then 25 Apr 2018, 13:38 for 2 sample programs to read a single and all input to the MCP3008.
diagram of connections
This should solve your problem.
One final point its not advisable to post a new question on a thread marked solved, I only picked it up because it appeared in the list of threads I have posted on, you would have been better to ask your question in a new thread , better still you could have searched the forum for posts about connecting the mcp3008 and found several similar posts related to your problem, including the one i liked to.
rompelstilchen
Re: Not getting any output from MCP3008 [solved]
Tue Jan 28, 2020 3:27 pm
why connect AGND to the RPI ?
this is obviously a gnd for the analog side of the ship
davidcoton
Tue Jan 28, 2020 3:39 pm
You realise you are replying to a year-old post?
See the MCP3008 data sheet, especially section 6.5 about grounding.
In most circumstances DGND and AGND should be connected close to the chip.
