must-be
trying to install apache with "sudo apt-get install apache2 -y" failed
Fri Sep 29, 2017 6:21 pm
i don't know why. maybe because i'm using with ssh?
i'm following :
https://www.raspberrypi.org/learning/la ... worksheet/
output:
https://gist.github.com/anonymous/953b0 ... 2e97915e96
edit:
perhaps because i didn't do "sudo apt-get update"?
raspi-owner
Re: trying to install apache with "sudo apt-get install apache2 -y" failed
Fri Sep 29, 2017 6:26 pm
maybe you must do a "sudo apt-get update" and "sudo apt-get upgrade" than restart installing apache2.
edit: yeah as you said.
DirkS
Fri Sep 29, 2017 6:27 pm
I think your package info is not up to date (I can see a version deb9u3 in the repo; you're requesting deb9u2)
Run 'sudo apt update' and then try again.
must-be
Fri Sep 29, 2017 6:44 pm
ok, thanks
so i did it and it was fine with the apache installation,
now i've another obstacle. i'm trying to install mysql but get:
pi@raspberrypi:/var/www/html $ sudo apt-get install mysql-server php5-mysql -y
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 php5-mysql : Depends: libmysqlclient18 but it is not installable
E: Unable to correct problems, you have held broken packages.
and i don't know how exactly to correct that
what do you say?
Fri Sep 29, 2017 6:47 pm
It's trivial to fix that.
viewtopic.php?t=191380#p1205095
must-be
Fri Sep 29, 2017 6:59 pm
hi
i'm not sure i understand what it says
Fri Sep 29, 2017 7:03 pm
Download a *.deb file with wget, install the *.deb file with sudo dpkg -i.
I only gave you a link to save typing all that stuff out again.
must-be
Fri Sep 29, 2017 7:48 pm
i've done:
sudo dpkg -i libmysqlclient18_5.5.57-0+deb8u1_armhf.deb
but i still get an error with mysql
Fri Sep 29, 2017 8:01 pm
Has mysql been replaced with mariadb on your system?
must-be
Sat Sep 30, 2017 9:41 pm
i don't know
how to check? what to do?
at the moment the only reason i need wordpress is so i can access my updrafts plus backups and extract information from there.
edit:
if i will start all over again with raspbian lite (a fresh install), will that solve the problem?
Sat Sep 30, 2017 10:52 pm
Since we don't know what your problem is, it's somewhat impossible to tell you.
W. H. Heydt
Sun Oct 01, 2017 2:09 am
Looking at the command that is giving trouble, I suspect it's the order in which the operands are given. Shouldn't it be "sudo apt-get install -y <packagename>" rather than the force '-y" flag being at the end?
must-be
Sun Oct 01, 2017 7:57 am
isn't it what being said at:
should it be that hard to follow the guide?
i'm not sure how to write instead of:
Sun Oct 01, 2017 10:21 am
Have you resolved your libmysqlclient18 problem?
Have you downloaded the *.deb and installed it with sudo dpkg -i deb.file.name.goes.here.deb
must-be
Mon Oct 02, 2017 8:31 pm
i don't know. i don't think so.
not yet,
i'm not find what you said about it. i mean which .deb...
does all that means that there is a problem with the mentioned guide? because i followed exactly what it said but got stuck with the mysql thing.
Mon Oct 02, 2017 9:30 pm
Download both debs. One of them will install OK.
must-be
Mon Oct 02, 2017 9:51 pm
so i need to type:
how can i download the "libmysqlclient18_5.5.57-0+deb8u1_armhf.deb" file to the pi? i mean i use ssh to control it.
i've it on my desktop but i need the file on the pi if i understand you right.
if i did not said it already. my aim is to have my blog on my pi or pc and not share the blog with the world until i will improve it further. i mean i need to improve the content. not the system...
thanks
edit:
i've tried that but it failed at the end with installing the .deb
sudo wget http://security.debian.org/debian-security/pool/updates/main/m/mysql-5.5/libmysqlclient18_5.5.57-0+deb8u1_armhf.deb
--2017-10-02 21:52:45--  http://security.debian.org/debian-security/pool/updates/main/m/mysql-5.5/libmysqlclient18_5.5.57-0+deb8u1_armhf.deb
Resolving security.debian.org (security.debian.org)... 2401:2500:103:11a::74, 133.242.99.74
Connecting to security.debian.org (security.debian.org)|2401:2500:103:11a::74|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 630456 (616K) [application/x-debian-package]
Saving to: 'libmysqlclient18_5.5.57-0+deb8u1_armhf.deb'
libmysqlclient18_5. 100%[===================>] 615.68K   302KB/s    in 2.0s
2017-10-02 21:52:48 (302 KB/s) - 'libmysqlclient18_5.5.57-0+deb8u1_armhf.deb' saved [630456/630456]
pi@raspberrypi:~/Downloads $ sudo dpkg -i libmysqlclient18_5.5.57-0+deb8u1_armhf.deb
(Reading database ... 123525 files and directories currently installed.)
Preparing to unpack libmysqlclient18_5.5.57-0+deb8u1_armhf.deb ...
Unpacking libmysqlclient18:armhf (5.5.57-0+deb8u1) over (5.5.57-0+deb8u1) ...
dpkg: dependency problems prevent configuration of libmysqlclient18:armhf:
 libmysqlclient18:armhf depends on mysql-common (>= 5.5.57-0+deb8u1); however:
  Package mysql-common is not installed.
dpkg: error processing package libmysqlclient18:armhf (--install):
 dependency problems - leaving unconfigured
