How to configure my WIFI via Bluetooth or WIFI Static IP
Posted: Wed Sep 27, 2017 2:03 am
by bnadams8
So I am still somewhat new to these Raspberry Pis but I have come across an issue that I would like to solve. I believe it can be done so I am reaching out to you guys to see if you can help.
I move my raspberry pi around a lot and I never carry around a keyboard and mouse with me because that would just be weird. Now ideally I would like to turn on my Raspberry Pi and have it giving off a wifi signal where I could connect to it with my phone or laptop. Once done I would like to be able to visit a static IP like 192.168.0.1:88 and be presented a page where I can enter my wifi credentials to my home wifi so my Pi can connect to wifi. Can this be done? If not done with wifi can I do bluetooth?
I am still new to this but I have done some research. I found this https://github.com/sabhiram/raspberry-w ... -wifi-conf but the install did not go very well for me with my lack of knowledge. Maybe someone could assist me there?
Anyways what are your guys thoughts? Is there a better way to have this done? Thanks!
Re: How to configure my WIFI via Bluetooth or WIFI Static IP
Posted: Wed Sep 27, 2017 10:45 am
by jbudd
An alternative approach to consider:
Use your phone as a mobile hotspot, with the access credentials in /etc/wpa_supplicant/wpa_supplicant.conf on the PI
At a new location, turn on the mobile hotspot and the Pi will automatically connect.
Then you need to append the new network credentials to /etc/wpa_supplicant/wpa_supplicant.conf. That could be by manually editing it via ssh or some fancier method.
Reboot the Pi and turn off your mobile hotspot. If you got everything right, it should connect.
