16 PWM outputs at 1 MHz using Raspberry Pi
Posted: Tue Sep 26, 2017 4:43 pm
I am currently working on multi phase Buck conveter and I want to drive FETs using Gate drivers from Microchip Technology. So I require 12 PWM outputs at 1 MHz which will be interleaved. 6 of these would drive the top FETs' drivers and 6 would be driving the Bottom FETs' drivers. I need very fast switching with low jitter and am thinking of using Raspberry pi for bread board design before I used FPGA. Is is possible to get 12 PWM outputs at 1 MHz using any Raspberry Pi model? I read a lot of articles and many say that there are only 2 PWM outputs and I feel I need to use Adafruit 16 channel servo driver with 12 bit PWM and I am confused. Please let me know regarding this.
Thank you.
Thank you.
