SusKahl
how to install GPIO on Zero
Mon Sep 18, 2017 1:44 pm
sorry for the misleading headline.
Im trying to follow this tourial
https://learn.adafruit.com/adding-basic ... -pwm-audio
I have installed
Raspian Stretch
Then I run
sudo apt-get install raspi-gpio
and when I type
gpio -v
I get the error
-bash: gpio: command not found
what am I doing wrong?
pcmanbob
Re: how to install GPIO on Zero
Mon Sep 18, 2017 2:01 pm
Hi.
seeing as you installed raspi-gpio then you need to use that to run the program try
raspi-gpio help
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Mon Sep 18, 2017 2:18 pm
The tutorial is a bit misleading. It is mixing up two packages: wiringpi and raspi-gpio. Wiring Pi has the gpio command and can be installed with sudo apt-get install wiringpi
pcmanbob has already pointed out the other one.
FTrevorGowen
Mon Sep 18, 2017 4:06 pm
rpdom wrote: The tutorial is a bit misleading. It is mixing up two packages: wiringpi and raspi-gpio. Wiring Pi has the gpio command and can be installed with sudo apt-get install wiringpi
Note however, for the "full" Raspbian distro. wiringPi is (should be) already installed (W.r.t. Raspbian Lite IJDK). A (quite useful) quick test is gpio readall**
Trev.
** FWIW, some example outputs for various Pi's are here: http://www.cpmspectrepi.uk/raspberry_pi ... adall.html
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
SusKahl
Tue Sep 19, 2017 1:11 pm
Thanks to all 3 of you. Im now a bit closer to my gold.
Who is online
Users browsing this forum: david_1234, lmarmisa, SkyRise and 52 guests
