Sp00kie13
EnviropHat
Fri Sep 15, 2017 4:14 pm
Hi Guys
Im after a bit of help
Ive just got the enviro pHat from pinoroni and am trying to set it up in my PiClock that ive set up on my PiZero W
Ive tried to install the software but when I run in through Python
This is what I get.
Raspberian was installed through Noobs as I dont have access to a keyboard so everything has to be done through my vnc server
B.Goode
Re: EnviropHat
Fri Sep 15, 2017 4:29 pm
Probably a question best raised directly with Pimoroni, the suppliers and developers.
At a quick glance it seems that the tutorial here: https://learn.pimoroni.com/tutorial/san ... nviro-phat is written using Python2, whereas you are using Python3.
Do you get the same error if you follow the instructions on that page?
MarkDH102
Re: EnviropHat
Sat Sep 16, 2017 10:09 am
Have you enabled I2C in the Preferences-->Configuration-->Interfaces panel?
alphanumeric
Re: EnviropHat
Sat Sep 16, 2017 1:27 pm
Be careful when installing packages, example
sudo python setup.py install < Installs as Python 2, run it from idle3 and it will fail with errors like your seeing.
sudo python3 setup.py install < Installs for use with Python 3. This has caught me out a few times.
Try running your python script from idel2 and see what happens.
If you used the Pimoroni Dashboard, or the one line installer this shouldn't be your issue. Just a heads up anyway, just in case you did things manually.
