No lol. I didn't even notice until you mentioned it.
Connecting two GPIOs together, driving one high and the other low, is (somewhat*) equivalent to both of those together.If you drive the pad high and it is shorted to ground in due time it will blow up!
The same holds true if you connect it to 3V3 and drive it low.
It is not equivalent.Burngate wrote: ↑Tue Sep 12, 2017 10:37 amJust as a matter of interest, https://www.scribd.com/doc/101830961/GPIO-Pads-Control2 gives the gory details.
On page 2 is the statementConnecting two GPIOs together, driving one high and the other low, is equivalent to both of those together.If you drive the pad high and it is shorted to ground in due time it will blow up!
I think you will benefit from a short course in basic electronics, So the breadboard is your next stepkreisler wrote: ↑Mon Sep 11, 2017 6:31 pmThanks for the detailed answer. I am beginner, so let's assume that the Pi3 has a fresh installation of Raspbian Stretch with nothing further. We do a sudo update&upgrade and reboot.
Once the Pi3 has booted, i don't know which state those two GPIO pins have. What would your guess be? Any harm when shorting those two pins after the fresh installation+fresh boot?
Yeah...11Kv would really make you light up. When I was a student, the basement of the EE building had a bunch of motor-generator (MG) sets. The biggest had a DC output side that was 1Kv at 980A. I think it was used to charge the 250KJ capacitor bank in the plasma experiment lab. The capacitor bank was charged in parallel and discharged in serial...boyoh wrote: ↑Tue Sep 12, 2017 3:14 pmI think you will benefit from a short course in basic electronics, So the breadboard is your next stepkreisler wrote: ↑Mon Sep 11, 2017 6:31 pmThanks for the detailed answer. I am beginner, so let's assume that the Pi3 has a fresh installation of Raspbian Stretch with nothing further. We do a sudo update&upgrade and reboot.
with emphasis on using the multi meter ,when testing assume the circuit is alive and not dead ,do not
take things for granted, I worked on testing factory 11kv Ring main systems , if I took a cavalier
attitude to testing I would not be writing this post
When I was a kid* I was taken to the Science Museum, where they had a demonstration of a large spark. They may still have it, for all I know.W. H. Heydt wrote: ↑Tue Sep 12, 2017 4:07 pmYeah...11Kv would really make you light up. When I was a student, the basement of the EE building had a bunch of motor-generator (MG) sets. The biggest had a DC output side that was 1Kv at 980A. I think it was used to charge the 250KJ capacitor bank in the plasma experiment lab. The capacitor bank was charged in parallel and discharged in serial...
I remember seeing it in action once. I looked for it last time I was there (about 10 years ago), but it seemed to have gone. Probably deemed too dangerous now.
