pnaven03
How to set time and date in boot time
Fri Sep 08, 2017 4:48 am
We are using raspberry pi board and kernel version Linux raspberry pi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux,
How to set time and date in boot time using shell script or c code , in case date and time corrupted how to check c code or shell script and update in run time,please any one help me on this.
klricks
Re: How to set time and date in boot time
Fri Sep 08, 2017 5:11 am
If your RPi is not connected to the Internet then you will need a RTC module with battery backup. Setting the clock depends on which module you get.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
pnaven03
Fri Sep 08, 2017 5:15 am
Thank you for the reply,
I need information only set time and date in boot time with ntp server , we are using RTC module in device to write "sudo hwclock -w"
my problem is how to sync time and date from servers in boot time.
ab1jx
Fri Sep 08, 2017 5:43 am
That sounds messy to get working the first time if I'm understanding you correctly. You have a hardware RTC clock? See man ntp and man ntp.conf. It's possible to set NTP to use a hardware clock and ignore the internet but the configuration isn't simple. A few years ago I had a machine getting the time via shortwave radio audio. Beyond the man pages you should probably look at http://www.ntp.org/ There are a few different RTC clocks I think and they'll work slightly differently. Exhaust any documentation that came with it. GPS time is also very accurate and can be used.
Or is it how to use NTP? Look at how to enable the service, then edit /etc/ntp.conf. I think this is mostly the stock file, I set it up a couple years ago.
# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
# Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
# You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example
# pool.ntp.org maps to about 1000 low-stratum NTP servers.  Your server will
# pick a different set every time it starts up.  Please consider joining the
# pool: <http://www.pool.ntp.org/join.html>
server 0.debian.pool.ntp.org iburst
server 1.debian.pool.ntp.org iburst
server 2.debian.pool.ntp.org iburst
server 3.debian.pool.ntp.org iburst
# Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
# details.  The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions>
# might also be helpful.
# Note that "restrict" applies to both servers and clients, so a configuration
# that might be intended to block requests from certain clients could also end
# up blocking replies from your own upstream servers.
# By default, exchange time with everybody, but don't allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
# Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
# Clients from this (example!) subnet have unlimited access, but only if
# cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
# If you want to provide time to your local subnet, change the next line.
# (Again, the address is an example only.)
#broadcast 192.168.123.255
# If you want to listen to time broadcasts on your local subnet, de-comment the
# next lines.  Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
A hardware clock would need a clock line in there and remove or comment out the server lines, from memory.
pnaven03
Fri Sep 08, 2017 6:10 am
ab1jx,
Thank you so much for reply,
I changed as per your configuration, but time and date is invalid,please check the below logs,
[email protected]:~ $ date
Fri 4 Jul 00:17:20 IST 2014
[email protected]:~ $ sudo timedatectl status
Local time: Fri 2014-07-04 00:17:15 IST
Universal time: Thu 2014-07-03 18:47:15 UTC
RTC time: n/a
Time zone: Asia/Kolkata (IST, +0530)
NTP enabled: yes
NTP synchronized: yes
RTC in local TZ: no
DST active: n/a
ab1jx
Fri Sep 08, 2017 6:27 am
I don't know, mine says:
      Local time: Fri 2017-09-08 02:17:01 EDT
  Universal time: Fri 2017-09-08 06:17:01 UTC
        RTC time: n/a
       Time zone: America/New_York (EDT, -0400)
     NTP enabled: no
 RTC in local TZ: no
      DST active: yes
 Last DST change: DST began at
                  Sun 2017-03-12 01:59:59 EST
                  Sun 2017-03-12 03:00:00 EDT
 Next DST change: DST ends (the clock jumps one hour backwards) at
                  Sun 2017-11-05 01:59:59 EDT
                  Sun 2017-11-05 01:00:00 EST
I don't get how NTP could be enabled and synchronized yet the local time is wrong. Is the time zone right? If you just changed it, let it sit a while. There are restrictions on how fast the time can change (slew).
Try the command ntpdate and the address of an NTP server to manually get the time from the server.
ab1jx
Fri Sep 08, 2017 6:35 am
Oh, mine says: NTP enabled: no
So I don't know what I'm talking about, I thought it was working fine. Then again it's 02:30. It does agree with my phone.
pnaven03
Fri Sep 08, 2017 10:24 am
Any one help me on this issue.
ab1jx
Fri Sep 08, 2017 2:17 pm
The only thing I can think of is that it's a permissions issue. I think only root can change the time. But I have to wonder why you're having a problem at all. Raspbian was made for Pis which don't have real time clocks and there are millions of them out there. If you've got a spare SD try a fresh load, I think it works out of the box without doing anything. If it does then compare your configs.
Martin Frezman
Fri Sep 08, 2017 4:00 pm
Has OP ever confirmed whether he is or isn't connected to the inter-webs?
You should never need a RTC or have to do anything special at all (assuming running Raspbian) if you are normally connected to the Internet.
The whole idea of an RTC and/or needing to set the time manually only comes into play if you are running a Pi "off-net".
Note, however, that it *is* true that the time doesn't get set until the network connection is up and running. There will be a noticeable delay, especially if your net connection is via wireless, between initial bootup and when the time gets set correctly. I always notice this in that the desktop comes up, then a few seconds later, goes to screensaver. This is because when the wireless connects, it jumps the time forward by a huge leap, making xscreensaver think that the machine has been idle for a long time.
You can also see this in the "dmesg" output, where the first few screenfuls of stuff are time stamped at basically zero, then it jumps forward to the current time.
If this post appears in the wrong forums category, my apologies.
ab1jx
Fri Sep 08, 2017 7:48 pm
Dmesg, yes, also journalctl, 2 places to look for relevant error messages. I don't think NTP normally does any logging unless stats is turned on in /etc/ntp.conf but they appear in /var/log/ntpstats. /var/log/daemon.log might show kind of explanation. In all 3 of those it's probably safe to search for ntp or NTP and start reading there, at least on a first pass. Most of the stuff will be irrelevant.
But also true, if there's no network connection NTP can't do anything. That should get logged somewhere.
Mine in fact has never been changed from the "factory" settings in /etc/ntp.conf. Before I change a file like that I copy it to something like ntp.conf.original and I saw one of those so I thought I might have changed it. I just did a cmp and I haven't changed it, so completely stock is working fine. On 2 Pi 3s and a Zero.
If you do
systemctl -a | grep -i ntp
you should see something like
ntp.service loaded active running LSB: Start NTP daemon
pnaven03
Mon Sep 11, 2017 4:25 am
Thanks for the reply,
My logs messages:
[email protected]:~ $ systemctl -a | grep -i ntp
● openntpd.service masked inactive dead openntpd.service
My raspberry pi connected to Ethernet and wifi network.
pnaven03
Tue Sep 12, 2017 3:58 am
Every reboot date and time is starting from
Mon 7 Jul 03:47:11 PDT 2014
Not current time , how to get the current date and time , any changes required in raspberry board,
please any one help me on this issue.
Tue Sep 12, 2017 6:47 am
The last thing fake-hwclock does when you shut down your RPi is write the current date/time to your SDCard. On reboot fake-hwclock restores then time from it's safe store (unless you install RTC hardware).
If those data are not being reliably stored you'll see your symptoms. One thing SDCards do near end-of-life is to go read-only (remember they were designed for cameras - that's to protect your photos). So the best advice I can offer is get a new SDCard and an SDCard reader. Boot the suspect card, use the Raspbian Pi Cloning tool to copy to the new SDCard (in the USB reader) swap cards and see if that solves your problem. Then take the old SDCard and run some card integrity tests on it.
If the tests work, save the card as a backup, if the test fail, toss it in the bin.
This is a doctor free zone.
Killertechno
Sun Dec 09, 2018 6:34 pm
Hi guys, may I ask where raspberry does save date at poweroff?
I mean, where does raspberry read date after boot?
I'm using latest raspbian, I set /etc/fake-hwclock.data file with dummy time (1th Jan 2000) and set it with read-only permissions.
At boot I get time updated to 2016 without RTC and no ntp connection....
Thanks.
DirkS
Sun Dec 09, 2018 6:48 pm
Does it set the date to the 2016/04/15?
If yes then check out the fake-hwclock script (it's in /sbin)
meingraham
Thu Feb 07, 2019 6:16 pm
I noticed in the last couple of days that my Raspberry Pi (3B) clock was off by several seconds (it turned out to be 23.311317 seconds).
I updated my system time by executing the following commands:
service ntp stop
ntpdate -b 0.us.pool.ntp.org
service ntp start
ntpdate reported that it had made a 23.311317 second correction.
This much drift did not seem possible because I had rebooted my RPi just a couple of days ago. So, after correcting the time, I decided to reboot the system to make sure that the time was still OK. Nope. This time it was off by 11.478837 seconds.
Why is my system not syncing with the configured NTP pool of servers when it reboots?
Regards.
Mike
# service ntp status
● ntp.service - LSB: Start NTP daemon
Loaded: loaded (/etc/init.d/ntp; generated; vendor preset: enabled)
Active: active (running) since Thu 2019-02-07 10:57:47 EST; 2h 9min ago
Docs: man:systemd-sysv-generator(8)
Process: 3475 ExecStop=/etc/init.d/ntp stop (code=exited, status=0/SUCCESS)
Process: 3565 ExecStart=/etc/init.d/ntp start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/ntp.service
└─3576 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 112:117
Feb 07 13:05:19 Pi ntpd[3576]: Soliciting pool server 208.75.88.4
Feb 07 13:05:21 Pi ntpd[3576]: Soliciting pool server 45.33.48.4
Feb 07 13:05:32 Pi ntpd[3576]: Soliciting pool server 2604:a880:800:10::1:9001
Feb 07 13:06:18 Pi ntpd[3576]: Soliciting pool server 107.175.144.206
Feb 07 13:06:23 Pi ntpd[3576]: Soliciting pool server 142.147.92.5
Feb 07 13:06:25 Pi ntpd[3576]: Soliciting pool server 198.55.111.50
Feb 07 13:06:39 Pi ntpd[3576]: Soliciting pool server 2001:4998:58:183a::1001
Feb 07 13:07:25 Pi ntpd[3576]: Soliciting pool server 216.6.2.70
Feb 07 13:07:29 Pi ntpd[3576]: Soliciting pool server 69.89.207.199
Feb 07 13:07:29 Pi ntpd[3576]: Soliciting pool server 162.213.2.253
ntp.conf
server 127.127.1.0# local clock
fudge 127.127.1.0 stratum 12
pool 0.us.pool.ntp.org iburst
pool 1.us.pool.ntp.org iburst
pool 2.us.pool.ntp.org iburst
pool 3.us.pool.ntp.org iburst
restrict -4 default kod notrap nomodify nopeer noquery limited
restrict -6 default kod notrap nomodify nopeer noquery limited
restrict 127.0.0.1
restrict ::1
restrict 192.168.1.0 mask 255.255.255.0 notrap nomodify noquery
# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:8e:38:0f brd ff:ff:ff:ff:ff:ff
inet 192.168.1.11/24 brd 192.168.1.255 scope global eth0
inet6 fe80::8950:eafa:c5f:2cdd/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:db:6d:5a brd ff:ff:ff:ff:ff:ff
inet 192.168.1.45/24 brd 192.168.1.255 scope global wlan0
inet6 fe80::b78b:81ca:7487:29b7/64 scope link
# ip route
default via 192.168.1.1 dev eth0 src 192.168.1.11 metric 202
default via 192.168.1.1 dev wlan0 src 192.168.1.45 metric 303
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.11 metric 202
192.168.1.0/24 dev wlan0 proto kernel scope link src 192.168.1.45 metric 303
# ping -c3 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.754 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.799 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.752 ms
--- 192.168.1.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2026ms
rtt min/avg/max/mdev = 0.752/0.768/0.799/0.031 ms
# ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=119 time=12.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=119 time=12.7 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=119 time=12.2 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 12.293/12.510/12.774/0.237 ms
# ping -c3 google.com
PING google.com (172.217.7.142) 56(84) bytes of data.
64 bytes from iad30s08-in-f142.1e100.net (172.217.7.142): icmp_seq=1 ttl=52 time=34.1 ms
64 bytes from iad30s08-in-f142.1e100.net (172.217.7.142): icmp_seq=2 ttl=52 time=25.6 ms
64 bytes from iad30s08-in-f142.1e100.net (172.217.7.142): icmp_seq=3 ttl=52 time=26.2 ms
--- google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2054ms
rtt min/avg/max/mdev = 25.628/28.653/34.111/3.871 ms
# ping -c3 0.us.pool.ntp.org
PING 0.us.pool.ntp.org (74.82.59.150) 56(84) bytes of data.
64 bytes from PBX.cytranet.net (74.82.59.150): icmp_seq=1 ttl=49 time=77.7 ms
64 bytes from PBX.cytranet.net (74.82.59.150): icmp_seq=2 ttl=49 time=77.4 ms
64 bytes from PBX.cytranet.net (74.82.59.150): icmp_seq=3 ttl=49 time=77.3 ms
--- 0.us.pool.ntp.org ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 77.344/77.506/77.761/0.291 ms
Gavinmc42
Fri Feb 08, 2019 12:57 am
I'm behind a firewall so I have to wait for an assigned IP address and then check the NTP server.
This goes into one of the shell boot scripts, x.x.x.x is the local NTP server.
A Pi connected to the net will grab time from the internet NTP server.
[checkdate="$( date "+%Y" )"
echo $checkdate
while [ "$checkdate" -eq "1970" ]
do
    ntpd -p x.x.x.x
    checkdate="$(date "+%Y" )"
    echo $checkdate
    sleep 5
done  /code]
Linux default year is 1970.
With no net/time it stays in the loop, so no rubbish data is logged.
A real RTC would make life easier ;)
I'm dancing on Rainbows.
meingraham
Fri Feb 08, 2019 1:09 am
This is a home network so I don't have a local NTP server. Thus I want it to sync it's time from the pool of Internet NTP servers I have configured in my not.conf. How should I modify the script to request the sync from the Internet? What should I replace x.x.x.x with?
Gavinmc42
Fri Feb 08, 2019 1:27 am
Raspbian and most Linux OS's will find the internet NTP servers without help.
Check your ip address, is it local 192.168,.x..x or 10.x.x.x ?
meingraham
Fri Feb 08, 2019 1:45 am
# ip route
Gavinmc42
Fri Feb 08, 2019 6:16 am
Wonder if it could be your router?
meingraham
Fri Feb 08, 2019 1:00 pm
I would think that if my router is blocking access to the NTP resources, that I would not be able to sync time manually either. A time sync performed interactively via the command line completes successfully.
Gavinmc42
Sat Feb 09, 2019 12:23 am
Good to rule out that then
Tried different OS's or new Raspbian install?
Sounding more like a script issue now.
meingraham
Sat Feb 09, 2019 12:54 am
I haven't implemented the script you suggested. I had a question earlier. Since I want to sync with an Internet NTP server, what should my x.x.x.x value be?
Return to “Beginners”
