Gaizka
Read encoder signal and read it on screen
Tue Sep 05, 2017 12:06 pm
Hi to everyone, i'm at very beginning stage with raspberry. As report in the topic title, I would like to read the encoder signals, in particular from an incremental encoder 1000 lap pulses (https://www.elcis.com/elcis/ENGLISH/cat ... /E0059Z.pdf).
I begin from this script:
import RPi.GPIO as GPIO
import time
RoAPin = 12    # CLK Pin
RoBPin = 26    # DT Pin
globalCounter = 0
flag = 0
Last_RoB_Status = 0
Current_RoB_Status = 0
def setup():
GPIO.setmode(GPIO.BOARD)       # Numbers GPIOs by physical location
GPIO.setup(RoAPin, GPIO.IN)    # input mode
GPIO.setup(RoBPin, GPIO.IN)
def rotaryDeal():
global flag
global Last_RoB_Status
global Current_RoB_Status
global globalCounter
Last_RoB_Status = GPIO.input(RoBPin)
while(not GPIO.input(RoAPin)):
Current_RoB_Status = GPIO.input(RoBPin)
flag = 1
if flag == 1:
flag = 0
if (Last_RoB_Status == 0) and (Current_RoB_Status == 1):
globalCounter = globalCounter + 1
if (Last_RoB_Status == 1) and (Current_RoB_Status == 0):
globalCounter = globalCounter - 1
def loop():
tmp = 0 # Rotary Temperary
while True:
rotaryDeal()
if tmp != globalCounter:
print 'globalCounter = %d' % globalCounter
tmp = globalCounter
                        #f = open('file.txt', 'wb')
                        #f.write('GlobalCounter= %d'%globalCounter)
                        #f.close()
def destroy():
GPIO.cleanup()             # Release resource
if __name__ == '__main__':     # Program start from here
setup()
         try:
     loop()
           destroy()
and I write this one:
import time
from kivy.app import App
from kivy.uix.gridlayout import GridLayout
from kivy.uix.label import Label
from kivy.config import Config
from kivy.core.window import Window
from kivy.clock import Clock
#Clock.max_iteration = 20
from kivy.uix.widget import Widget
globalCounter = 0
flag = 0
Last_RoB_Status = 0
def setup(dt):
Clock.schedule_once(setup, 0)
def funct(dt):
global flag
for i in range (61):
  if (not GPIO.input(RoAPin)) :
                 flag = 1
           if flag == 1:
   flag = 0
   Clock.schedule_once(funct,0)
Class FlickerGUI(GridLayout):
    def __init__(self, **kwargs):
        super(FlickerGUI, self).__init__(**kwargs)
        self.cols = 1
        self.add_widget(Label(text='Saturation Level'))
        self.sat_label = Label(text=str(globalCounter))
        self.add_widget(self.sat_label)
        Clock.schedule_once(setup,0)
        Clock.schedule_once(self.update_labels,0)
    def update_labels(self, *args):
        self.sat_label.text = str(globalCounter)
class MyApp(App):
    def build(self):
        return FlickerGUI()
MyApp().run()
GPIO.cleanup()
I'm able to read encoder but not in the right way, someone could help me to wirte the script in a good way, maybe is possicle work on the for cycle, or everithing is wrong?
Thank you in advance
