malakai
Trying to set eth0 to 100 full duplex no autonegotiate
Tue Oct 02, 2012 8:35 pm
Below is the setup but at the end I append /etc/network/interfaces and run sudo ethtool eth0 and it still says auto yes
I used this line in the file:
up sleep 5; ethtool -s eth0 autoneg off speed 100 duplex full
If I run ethtool -s eth0 autoneg off speed 100 duplex full
Then run sudo ethtool eth0
It says auto is off any ideas anyone?
INSTALL SETUP
Install mii-tool and ethtool tools
Install both of these package with following command:
# sudo apt-get install ethtool net-tools
Task: Get speed and other information for eth0
Type following command as root user:
# sudo ethtool eth0
Output:
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: d
Current message level: 0x00000007 (7)
Link detected: yes
Setup eth0 negotiated speed with ethtool:
# sudo ethtool -s eth0 speed 100 duplex full
# sudo ethtool -s eth0 speed 10 duplex half
Putting this into /etc/network/interfaces so it will always be set to 100 full duplex:
# sudo nano /etc/network/interfaces
My file looks like this:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
add the following at the end:
up sleep 5; tells it to wait for the autonegotiation to complete then sets the speed.
Save and quit.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
ski522
Re: Trying to set eth0 to 100 full duplex no autonegotiate
Wed Oct 03, 2012 5:12 pm
You're probably having the problem because you don't have the full path of where ethtool is located...but that's not really the best way to do that. Do this instead
cd
1) sudo nano /etc/init.d/autoneg
#!/bin/bash
/sbin/ethtool -s eth0 autoneg off speed 100 duplex full
exit
[save file]
2) chmod a+x  /etc/init.d/autoneg
3) Run at startup by typing at shell prompt
update-rc.d -f  /etc/init.d/autoneg defaults
I haven't tested this on the Pi, but believe this will do what you're looking for
Nehemoth
Tue Apr 02, 2013 1:30 am
Did not work for me.
Nehemoth
Tue Apr 02, 2013 2:04 am
In Debian (also Raspberry pi) this is the way to do it as per document
/usr/share/doc/ethtool/README.Debian
link-speed 100
link-duplex full
ethernet-autoneg off
works like a charm
