fjr
install flashrom on rp 0
Wed Aug 02, 2017 8:28 pm
flashrom.org. I want to install flashrom on rp 0. I do not know where to start. Can you give me instructions? Thank you.
Re: install flashrom on rp 0
Wed Aug 02, 2017 8:52 pm
pleriche
Sat May 05, 2018 9:31 pm
In case anyone is watching this or stumbles across it, I downloaded the source and successfully built it to drive SPI devices through /dev/spi* with:
make CONFIG_ENABLE_LIBPCI_PROGRAMMERS=no CONFIG_ENABLE_LIBUSB0_PROGRAMMERS=no CONFIG_ENABLE_LIBUSB1_PROGRAMMERS=no
It appeared to work, typing
./flashrom -p linux_spi:dev=/dev/spidev0.0
but nevertheless failed to detect the flash on a Bluetooth chip I wanted to reprogram.
And I can now confirm that it builds successfully following the recipe referenced by Dougie, i.e.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install pciutils libftdi-dev libusb-dev libpci-dev libusb-1.0
make flashrom
(On further research and reflection I've concluded that the SPI port I was accessing is a debug port, not a flash rom port, hence I didn't see any rom. There's a separate I2C rom chip on the board which I guess contains the settings I wanted to get at.)
fjr
Sun May 13, 2018 3:03 pm
If you install raspbian via noobs flashrom 0.9.9 r1954 is available.
