Raspberry pi zero W
Posted: Mon Jul 31, 2017 5:29 pm
by BUBLOSq2
i want to do the raspberry zero dongel computer project its very populer in the last time. I have the ver. 1.1(Rasp.W) of the zero and i have no laters on the other side of the pi (the 1.3v have the letters). My question is, cann i do the same on the 1.1v just soldering it to the same points as on the videos? or is the Raspberry Zero W not compatible?
Thanks!
Re: Raspberry pi zero W
Posted: Mon Jul 31, 2017 8:16 pm
by B.Goode
BUBLOSq2 wrote: ↑Mon Jul 31, 2017 5:29 pm
Thanks!
It is very likely that most users of this forums will not know what " the raspberry zero dongel computer project" is.
Could you be specific about which videos you are referring to?
Posted: Mon Jul 31, 2017 8:56 pm
by BUBLOSq2
The video: "
https://www.youtube.com/embed/qbWYUFgLhSU? at:1:42 you can see that the back of the Raspberry pi Zero 1.3v have all this signs on the back and my 1.1v doesent have, so my question is, will it work if i just solder it in the same point as he did.
Dongle projcet, sory for my mistake!
Posted: Mon Jul 31, 2017 9:18 pm
by jamesh
Not sure why you created a second username to ask anther question - you can just ask questions!
Note, we do moderate first posts, so first posts will not appear straight away, they have to be checked first.
Posted: Tue Aug 01, 2017 3:28 pm
by BUBLOSq2
Yes sory, this is my second account. I hoppe this is not a big problem.
Posted: Tue Aug 01, 2017 3:38 pm
by alphanumeric
https://www.raspberrypi.org/magpi/stick-pc-pi-zero/ The only issue is getting the right test points. They have moved around some depending on what version of the Zero You have. shouldn't be to hard to figure out what's what though.
According to this, the test points are in the same positions for the V 1.1 and 1.3
https://zerostem.io/
This backs that up,
https://shop.pimoroni.com/products/zero ... connector
Posted: Tue Aug 01, 2017 3:51 pm
by BUBLOSq2
Thank you so much, i have alot to learn about raspberry
Posted: Tue Aug 01, 2017 3:56 pm
by alphanumeric
No problem, have fun. =)
