How to configure Rpi on two wireless networks ?
Posted: Mon Oct 01, 2012 4:39 am
by NewPi
I have two wireless networks - one at Home and one at office, I used wpa_gui to configure my Home WiFi with RPi and connected successfully. My current "interfaces" config is :
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
Now, I want to connect to my office wifi network and configure both wlan connections to have static IP's. Pls. guide how to achieve this ?
Re: How to configure Rpi on two wireless networks ?
Posted: Tue Oct 02, 2012 7:13 am
by RussoNC
Mmhh... seems like you want to do an VPN? If is that, you can use this tutorial that another user post:
http://www.raspberrypi.org/phpBB3/viewt ... 36&t=14535
Hope this is usefull, if not, tell me and I'll try to help you.
Posted: Wed Oct 03, 2012 3:02 pm
by NewPi
No I did not wanted an VPN, I wanted my Pi to have the same static IP address in wlan when connected to any one of the two wifi's.
Posted: Wed Oct 03, 2012 8:15 pm
by Lob0426
Your best bet might be to use one of the network managers. They allow settings for multiple networks. The new Raspbian has one installed. I use network-manager-gnome. There are others out there also.
Posted: Thu Oct 11, 2012 4:03 am
by NewPi
Some Google searching and
WICD Network Manager did the trick
Posted: Thu Oct 11, 2012 4:31 pm
by thogue
I'd be interested in what the interfaces file looks like for this config. Or maybe wicd holds all that info.
Posted: Sat Oct 13, 2012 4:43 pm
by NewPi
thogue wrote:I'd be interested in what the interfaces file looks like for this config. Or maybe wicd holds all that info.
Here's the /etc/network/interfaces file :
auto lo
allow-hotplug wlan0
The /etc/wpa_supplicant/wpa_supplicant.conf file :
update_config=1
network={
ssid="MyOfficeWifi"
psk="areyoukiddingme"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
network={
ssid="Home_Network"
psk="reallyiwillpostithere"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
Posted: Sat Oct 13, 2012 4:56 pm
by Dweeber
You can also add priorities when you have say a temporary hotspot that you use for testing at a location where you have a normal access point.
By adding priority...
network={
ssid="HouseDefault"
psk="password"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
priority=5
network={
ssid="Rezound4G"
psk="password"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
priority=9
If both HouseDefault an Rezound4G are active at the location the Rezound SSID will be used because it has a higher default value. There are some great portable reasons to do this in a headless environment.
Posted: Sat Oct 13, 2012 6:19 pm
by thogue
Config is showing dhcp config a, did you setup reservations or am I missing something ? My configs look just like this.
Posted: Sun Oct 14, 2012 2:18 am
by NewPi
thogue wrote:Config is showing dhcp config a, did you setup reservations or am I missing something ? My configs look just like this.
No, I did no manual config. First set-upped using
wpa_config and then used
WICD to allot an static ip.
I guess WICD takes over to load the static IP while booting.
