ApurvPadole
USB Audio device
Mon Jul 17, 2017 6:02 am
Hello All,
I am trying to use USB audio card CM108 with Raspberry pi. Raspbian and Current version of Linux kernel is 4.9.20+.
Pleas walk me trough changes required to be made in the kernel so that we can use USB audio card.
Thanks and Regards
Apurv
Re: USB Audio device
Fri Jul 21, 2017 11:35 am
Boot the system. Plug it in. See what happens with a dmesg command. Some devices should appear in /dev for your USB audio.
The kernel should have the support for that stuff built-in.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
Fri Jul 21, 2017 12:03 pm
ApurvPadole wrote:Hello All,
Thanks and Regards
Apurv
There is nothing to change it is fully supported in Raspbain jessie:
uname -a
Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
lsusb
Bus 001 Device 005: ID 248a:8367
Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
cat /proc/asound/cards
 0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                      bcm2835 ALSA
 1 [Device         ]: USB-Audio - USB PnP Sound Device
                      C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.3, full spe
""understanding the theoretical, but not always the end goal""
My other Devices are the ChromeBit CS10, ChromeCast & Huawei Mate 10 Pro SmartPhone
Fri Jul 21, 2017 2:59 pm
fruitoftheloom wrote: There is nothing to change it is fully supported in Raspbain jessie:
That's cheating. You've got the hardware to try out.
MQTT Evangelist
Who is online
Users browsing this forum: No registered users and 38 guests
