Python Programming, invalid Syntax
Posted: Sun Jul 16, 2017 4:29 pm
by khse
I recently just got my raspberry model b with sensehat addon. This is my first time using such programming devices as python and I don't get why there is always a syntax error.
I'm writing my command in Python 3 (IDLE), run it (working) for one time, save it as a .py file. When I try to run the command again, a pop-up showing invalid syntax appears and I can't run it again. The LED screen of the Sensehat is stuck at that moment and I have to rewrite the whole command to run it again for one time.. Does anybody know why this is happening?
Command:
Python 3.4.2 (default, Oct 19 2014, 13:31:11)
[GCC 4.9.1] on linux
Type "copyright", "credits" or "license()" for more information.
from sense_hat import SenseHat
from time import sleep
from random import randint
sense = SenseHat()
r = randint(0,255)
sense.show_letter("O", (r,0,0))
sleep(1)
r = randint(0,255)
sense.show_letter("M",(0,r,0))
sleep(1)
r = randint(0,255)
sense.show_letter("G",(0,0,r))
sleep(1)
sense.clear()
Re: Python Programming, invalid Syntax
Posted: Mon Jul 17, 2017 2:56 am
by AussieSusan
If you are running IDLE, then the cursor will be placed in your source file at the point where the error was found. It should also have a highlight at the spot.
That should help you at least locate where the compiler is having problems.
Susan
Posted: Mon Jul 17, 2017 4:47 am
by gkreidl
Is ist possible that you are typing your code into Idle's shell window instead or using an editor window?
Posted: Mon Jul 17, 2017 6:45 am
by bensimmo
There are three places to run Python3 in Raspian now
IDLE3 which is where I assume you are editting and typing if you are following the sites Learn the SenseHAT lessons. You 'edit and run' the program from there.
You have a text editor window open and another IDLE3 terminal window that show you what is happening
The terminal window (black rectangular box for a command line) where you would run it as
Python3 theProgram.py
Now there is Thonny too, excellent program for learning on and learning to debug and follow how a program is running.
(Perhaps screenshot, though no idea if the usual prints teen key work in Raspbian desktop, there is no screenshot utility installed by default like Windows Snipping Tool and then you have to find a way of getting a picture up on here, it doesn't like 'normal size' pictures)
Posted: Mon Jul 17, 2017 7:43 am
by khse
The invalid Syntax is always at the Beginning:
Python 3.4.2 <-- the "4" is highlighted.
I'm not sure where I'm trying to run the command. Well I just click on the Python 3 Icon and start writing my command, when I press enter at the end, the commands starts running for one time. Then I'm saving the file on the desktop. Reopening it, you get one more option in the topbar of the file, I can "Run" the file pressing F5. But it won't work.
Posted: Mon Jul 17, 2017 7:44 am
by KLL
bensimmo wrote:Perhaps screenshot, though no idea if the usual prints teen key work in Raspbian desktop, there is no screenshot utility installed by default like Windows Snipping Tool and then you have to find a way of getting a picture up on here, it doesn't like 'normal size' pictures)
raspbian has SCROT
and already linked to [Print Screen]
can change like i did to also have print active window [Alt][Print] see
viewtopic.php?p=1132546#p1132546
looks like http://kll.engineering-news.org/kllfusi ... _print.jpg
possibly add a upload to dropbox...
Posted: Mon Jul 17, 2017 8:41 am
by KLL
http://kll.engineering-news.org/kllfusi ... creen1.jpg
here i used IDLE3 but NO HAT, so the program can not work.
so that is how the IDLE3 file edit window and the IDLE3 shell window can look.
here i operate via VNC / screen shot on win7 PC / upload server..
Posted: Mon Jul 17, 2017 9:17 am
by khse
I'm not getting it, so sorry. :/ What do I need to do that it works? The Pi and SenseHat is fully working. But thank you for your commitment so far!!
Posted: Mon Jul 17, 2017 9:39 am
by B.Goode
@gkreidl was most likely correct.
When you start up IDLE3, ignore the initial default Python Shell Window.
Open a new window via the File/New menu option.
Retype your script there, or if you wish edit your existing script to remove all the 'junk' that was added by Idle that you did not originally type.
The script should begin at
the first 4 lines in your saved file are superfluous.
Edit: added after checking the Raspberry Pi Foundation resource here:
https://www.raspberrypi.org/learning/as ... program.md
The first sentence of that resource says:
Open Python 3 using Menu > Programming > Python 3. This will cause a Python Shell window to appear. Select File > New File, and type in the following code:
Posted: Mon Jul 17, 2017 10:36 am
by khse
Thanks, I will try that! I'm currently overwriting and redownloading my SD-Card. I'll keep you updated!
Posted: Mon Jul 17, 2017 10:48 am
by gordon77
khse wrote:The invalid Syntax is always at the Beginning:
What editor are you using ? It's hard to make out your screenshot BUT why does it have the bit about python at the top ?
It seems to be seeing that as code ?
You need to open a new window and type your code in that ?
Posted: Mon Jul 17, 2017 10:53 am
by khse
The text at the top is there when I click on the Python 3(IDLE) icon to open a new file. I can not delete that apparently.
Posted: Mon Jul 17, 2017 11:24 am
by B.Goode
khse wrote:The text at the top is there when I click on the Python 3(IDLE) icon to open a new file. I can not delete that apparently.
Clicking on the Python 3 (IDLE3) entry on the Raspbian desktop menus opens a new instance of the IDLE 3 IDE/Editor. It does NOT open a new file.
Please see my reply a couple of hours ago for precise information from the Raspberry Pi Foundation about how to do this correctly.
Posted: Mon Jul 17, 2017 11:26 am
by gordon77
Once opened click on FILE, and then NEW FILE to open a new window, and type in that.
Don't type in the Python 3.4.2 Shell window
Posted: Mon Jul 17, 2017 11:59 am
by khse
Ok perfect, now it works fine. Thank you guys!
Posted: Mon Jul 17, 2017 3:07 pm
by bensimmo
KLL wrote:http://kll.engineering-news.org/kllfusi ... creen1.jpg
Change sense_hat to sense_emu and it should work (on a standard Raspian install)
Posted: Tue Jul 18, 2017 7:59 am
by KLL
bensimmo wrote:Change sense_hat to sense_emu
yes, but it was not the idea to make that program working, just to show how a file edit window / with his source code / looks like
but thanks for the nice idea!
http://kll.engineering-news.org/kllfusi ... at_emu.jpg
