grptx
4 digits 7 segments
Sun Jul 16, 2017 11:39 am
Hi all,
i'm a total beginner so please be patient with me.
i'm trying to display 4 digits on a 4*7 segments display using a ranspberry pi 3 using as example this tutorial
https://www.hackster.io/davek17/rpi-7-s ... 1ic-8972f5
but I have a strange behavior when a i switch between the digits. i made this video to explain my issue:
https://www.youtube.com/watch?v=cYtT2Qamb54
here my code:
void *displayDigits (void *dummy)
  uint8_t digit ,i;
  uint8_t index, d ;
  int delay = 150000;
  for (;;)
    for (digit = 0 ; digit < 4 ; ++digit)
      d = toupper (digits [digit]) ;
      index = d - '0' ;
      for(i=0;i<4;i++){
        digitalWrite (segments_ar[i], bcdD [index * 4+(3-i)]) ;
      digitalWrite (digits_arr[digit], 1);
      delayMicroseconds (delay);
      digitalWrite (digits_arr[digit], 0);
      if(delay>10000) {
        delay-=500;
        printf("delay :%d\n",delay);
In practice reducing the delay time until all 4 digits are displayed some of unexpected happens
here the components i using
C library: http://wiringpi.com/reference/
BCD : http://www.datasheetcatalog.com/datashe ... 11BC.shtml
transistors: https://www.onsemi.com/pub/Collateral/BC337-D.PDF
7 segments display: http://www.peterparts.com/CatalogPages/57/1023.pdf
p.s. sorry my bad English
rzusman
Re: 4 digits 7 segments
Mon Jul 17, 2017 4:22 am
You need to scope the outputs to determine exactly what is happening, but I’d bet that the rise or fall times of your outputs are too slow, and so multiple transistors are being turned on.
Posting your schematic would help.
grptx
Mon Jul 17, 2017 6:36 pm
here my schematic: http://www.enslavedcoder.org/sketch.jpg
about the timing I gradually decreased the delay in my code to find the optimal value
      if(delay>10000) {
        delay-=500;
I thought the correct value was about 16000 µs (60hz) but with this delay the digits are still overlapping and flickering
the problem can be the values of resistors on the base of transistors? (i using 1k now)
drgeoff
Mon Jul 17, 2017 6:52 pm
Try 220 ohm base resistors as in the tutorial.
grptx
Mon Jul 17, 2017 7:15 pm
I use 220 ohm between the bcd 4511 and the display and 1k ohm between the raspberry and the transistor .. as in the tutorial :cry:
Mon Jul 17, 2017 11:15 pm
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
grptx
Tue Jul 18, 2017 9:10 am
i have already did this project, but now i wish to use the bcd to reduce the GPIO lines
grptx
Sun Jul 23, 2017 2:07 pm
I solved by connecting the 4511 IC LE pin to ground :?
Who is online
Users browsing this forum: jbudd and 15 guests
